460 swap into a F-100
Let me give you a bit of background and then I will ask my questions.
I have a 1994 F-150 SCSB rear wheel drive chassis. It was a 5.0L and 5 speed truck. I removed the body and I am putting on a 1981 F-100 SCSB to this chassis because it is a lot better than the 81. I was going to go 5.0L and 4R70 from a 96 F-150 but I accidentally found a 1994 7.5L and E4OD combo. So i grabbed the whole harness and drivetrain and brought it home. I swapped out the 5.0 engine perches for the F250 460 ones. I already set the engine into place and found that the oil filter/oil cooler hit the cross member. My plan is to make the PCM as a stand alone harness so I can keep it clean in the engine bay. I also want to remove all the air injection stuff since it is not required where I live.
Now the questions.
1) Can I remove the oil cooler assembly and just run a FL-1A oil filter?
2) Does any one have pics of where I cut the cross member to clearance the oil filter?
3) When I remove the oil cooler off of the engine, can I use an earlier year of F250 with a 7.5L lower rad hose?
Thanks guys for the help.
Now the questions.
Now the questions.
Now the questions.
Also I would highly recommend getting the factory ford electrical and vacuum shop manual for modding your 460 harness. I made my 5.8L stand alone and couldn't have done it without that book. Got mine for about 80 bucks new on ebay.
Cutting the crossmember is an option but its not pretty. Check out this link for a pic: 1984 Ford Bronco 460 Swap picture | SuperMotors.net
Most people buy and install a remote oil filter kit.
OBD_F350
30
Jan 8, 2023 02:29 AM
Ken Newman
May 10, 2019 07:36 PM
Frijole
23
May 24, 2016 10:11 PM
