Headlight, Running light issue
Old Aug 27, 2020 | 11:46 AM
7.3_4Life's Avatar
7.3_4Life
No, They only come on when I pull the switch a little more out past 1/2 way
Old Aug 27, 2020 | 12:16 PM
Perk85F250's Avatar
Perk85F250
I suspect there is a bad connection on the fuse #4 circuit (tan/white) as mentioned earlier by Lone Wolf. Inspect the terminals in the fuse box for loose contact or corrosion. Wires on the back side of the fuse box can break, but it is rare. Click on the link for testing the light circuits and switch. The headlight circuit for your truck is basically the same.
https://troubleshootmyvehicle.com/fo...light-switch-1
Old Aug 27, 2020 | 12:28 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
How is that Possible IF you have no power on Terminal 'A' Tan/wht wire... .... if this is the case and you are getting park lights then either you have the wrong Headlight switch or the pigtail you wired in is not wired in correctly see the schematic I posted.
do a Continuity test on the switch to be sure it matches the functions of the Schematic ...Find out why you do not have power on the Tan/Wht wire ... it seems that you said you have power on Fuse #4 so is the wire burned open ???
IF you do not understand the schematic we can help with that too.
Old Aug 27, 2020 | 12:53 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
OK from the schematic you can call pin 'B' "B1" and call 'A' "B2" ... then you can use this guide https://troubleshootmyvehicle.com/fo...light-switch-1
Old Aug 27, 2020 | 02:17 PM
7.3_4Life's Avatar
7.3_4Life
The headlight circuit works, the parking light circuit does not.
Old Aug 27, 2020 | 03:06 PM
Perk85F250's Avatar
Perk85F250
Click on the link posted earlier, see page 3 for the park lights.
Old Aug 27, 2020 | 03:16 PM
7.3_4Life's Avatar
7.3_4Life
In my case B2 (Tan/Wht Wire) has no power. and its the same wire that runs to the fuse, right? The fuse has power, so im lost.
Old Aug 27, 2020 | 03:22 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I guess I missed your comment
Old Aug 27, 2020 | 03:24 PM
7.3_4Life's Avatar
7.3_4Life
The wire that runs from the fuse (Tan/Wht) runs behind a metal piece that holds the dash in place and I can get behind that to see where it goes.
Old Aug 27, 2020 | 03:26 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
right that wire runs from the fuse.
it should be hot at all times, IF not then the Park Lights will never come on.
IF fuse #4 has power on both sides of the Fuse then trace that wire to see where it is OPEN.
As mentioned it could be on the back of the fuse box where it connects to the fuse. or it could be a bad Splice.
Old Aug 27, 2020 | 05:07 PM
Perk85F250's Avatar
Perk85F250
You are on the right track. I strongly recommend going through the diagnostic steps using the trouble shoot website link.
If you find the fuse box or wiring to it is the problem, it may be more practical to bypass the fuse box. Install an inline fuse and additional length of wire from Batt+ to the tan/white wire near the headlight switch. Batt+>inline fuse>headlight switch.
I had to do a similar bypass for the blower motor circuit in my truck. The amp draw from the motor caused the fuse and terminals to melt. New inline fuse and blower motor fixed it.
Old Aug 27, 2020 | 06:58 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you have to add a new wire the easiest thing to do is just place a 15 AMP fuse between the Blk/Orn wire and the Tan/Wht wire, you can do this when splicing in the pigtail
See the Schematic I posted it will be between pin 'B' and 'A'
Old Sep 16, 2020 | 02:04 PM
  #28
7.3_4Life's Avatar
7.3_4Life
Little late now, today I ran a wire from the battery to the tan/white wire on the switch with an inline fuse, and everything worked when I pulled the switch out.
Old Sep 16, 2020 | 02:17 PM
  #29
DarkOverCast's Avatar
DarkOverCast
I had to do something similar for my running light power. So far no issues
Old Sep 16, 2020 | 03:15 PM
  #30
Perk85F250's Avatar
Perk85F250
Good to hear you got it fixed
mgdemarco
Jul 7, 2009 05:22 PM
Dutch123
1978 - 1996 Big Bronco
15
Feb 23, 2007 08:36 AM
a564jim
Aerostar
Jun 30, 2004 07:25 AM
69crewcab
Oct 19, 2003 09:52 PM
