Oversized tire PSI?
Old Aug 20, 2020 | 02:09 PM
Chaplee's Avatar
Chaplee
Oversized tire PSI?
I’m having a heck of a time figuring out what tire pressure to use for my oversized tires (LT285/65R18/E)...for daily, no-load Highway driving for my 05 Eddy Bauer Excursion 6.0. Max tire pressure is 80psi. Any wisdom out there?
Old Aug 20, 2020 | 02:17 PM
seville009's Avatar
seville009
It really depends on your comfort level for basic daily driving. I have mine at 72 psi year round, including plowing and towing.
Old Aug 20, 2020 | 02:26 PM
Chaplee's Avatar
Chaplee
PSI
Thanks...interesting you’d keep the same
pressure for towing. But “year round” sounds compelling!
Old Aug 20, 2020 | 02:48 PM
TooManyToys.'s Avatar
TooManyToys.
I alter my pressure depending on the load, I'm 285 over the stock 265. You can do the caulk test across the width and see the dispersion over a short distance, or use a tire depth gauge to see how the tread is wearing longer term. I never did well with the caulk so I take a little latex paint and swipe it just on the top of the tread with a rag, then let it dry. I've seen some people take a shipping adhesive label and put it across, then watch the contact wear of the paper in short order.
I'll be down to 65psi at the rear running empty, but up to the door rating with loads.
Old Aug 20, 2020 | 05:57 PM
MisterCMK's Avatar
MisterCMK
I usually keep 60-65psi in the front and 55-65 in the rears. I have 35x12.5x20 Toyo Open Country MTs. Load F.
Old Aug 21, 2020 | 02:17 AM
dhag911's Avatar
dhag911
I also have 285s. I'm running an 8 ply tire so I run them at the max 65 psi. When I had 10 plys I ran 70 psi in front all times backs at 70 unless towing then went to 80 got 55k miles out of a set of Firestone destination a\t
Old Aug 21, 2020 | 02:45 AM
jadatis's Avatar
jadatis
if they are that oversised , as you write, safe pressure can even be 30 psi.
I am able to calculate it for you, but need more information.
easyest are the GAWR'S , GVWR, empty weight, max speed you use( and wont go over for even a minute.
Then from tires, but some is given already.
1 maxload or loadindex (googled and found 125R)
2 loadrange ( your E = 80 psi for maxload)
3 speedcode, if you can find it. ( R is 170kmph/106mph)
also yudge if tires are ofroad( isch) with larger profile-blocks that cover part of sidewall( saw those agressiv profile-blocks that cover part sidewall )
Old Aug 21, 2020 | 10:00 AM
Chaplee's Avatar
Chaplee
PSI
Thanks to all for the advice about my oversized tires...I think the bottom line is: do not inflate to the max 80PSi; rather use a moderate PSI of 55-72PSI when everyday driving without a load.
lebby83
Jan 15, 2023 10:50 AM
GatorBait1996
Jan 5, 2011 12:14 PM
rb8484
Apr 1, 2009 10:24 AM
atomicjoe23
Sep 3, 2008 09:44 PM
katiesdad7
Nov 1, 2007 03:34 PM
