What tire pressure?
Old Aug 28, 2008 | 07:01 PM
atomicjoe23's Avatar
atomicjoe23
What tire pressure?
We bought a '79 Ford F-150 4x4 w/351M from auction (it was a steal at $800), only problem is that the tire pressures are all way higher than I think they should be (~50 psi) and it didn't come with an owner's manual and the driver's side door info plaque has been painted over (if it was a sticker) or removed (if it was metal) so I have no idea what the recommended tire pressure is for this truck.
Could someone look on their truck/owner's manual and tell me what the hot/cold pressures are for driving and towing for these older Fords?
Thanks!!!
Old Aug 28, 2008 | 07:26 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Look at the tires, they should have the recommended psi. 50 seems high for a half ton-usually pressures that high are for higher load rated tires for the F250's and up.
Usually 30-32psi is the norm. Depending on the tire, and vehicle, usage, etc.
Always check/adjust your tires after driving for a few miles, to heat the rubber up.
It is usually all depending on what the tire is capable of.
Old Sep 3, 2008 | 04:33 AM
atomicjoe23
Thanks guys. . .yeah. . .the psi on the side of the tire is for the maximum allowed pressure in the tire. . .the max for the tires that the truck came with are like 70 or 75 psi. . .which is not what you would run just maximum that it can "safely" handle. . .although I find that questionable. . .my girlfriend just had a blowout (from heat build-up) in her Cavalier because the tire was overinflated. . .the other front tire was at 60 psi!!! I fixed that REAL fast. . .knew what that should be at. . .usually run it at ~36 psi for better MPG).
I'm pretty sure that the truck should be a little higher than the car, I'm gonna shoot for around 40 psi and I'll see how the tires wear. . .and adjust (or not) the pressure based on the wear pattern of the tires I guess.
Thanks!
Old Sep 3, 2008 | 09:15 AM
beartracks's Avatar
beartracks
You can try running it through some water and checking the tread pattern before it evaporates. Another way I've seen is chalk or some other way of marking the tread pattern.
Old Sep 3, 2008 | 09:44 PM
atomicjoe23
Thanks Beartracks. . .that would definitely clue me in to whether the pressure was too high or too low a lot quicker than waiting for a wear pattern to develop. . .not to mention save me some money in the long run!!!
Hard to believe that I didn't think about that myself as I use chalk on my sportbike tires to check my lean angle on a ride. . .
