Power window issue
My passenger window just started bugging a little. At first the issue was ONLY with the passenger switch, but now the switch on the drivers side is bugging a little too. The passenger switch at first only had a problem intermittently, either rolling down or up. And it was not after using it a lot, so the motor wasnt hot. The Drivers switch worked all the time tho. Now, the passenger switch works once in awhile, and the drivers switch USUALLY works, but sometimes i have to hit it a few times before the passenger window responds. All of the other windows work properly from local switches and from driver door switches.
So... thoughts? would a bad switch on passenger door interfere with the driver side switch? Just looking for a place to start, rather than calling a $300+ mobile power window guy to come look at it. I am trying to sell this thing, after all.
