power window ?
Old Mar 12, 2005 | 10:57 AM
864x4stepside's Avatar
864x4stepside
Arrow power window ?
Power windows work fine except I cannot operate the passenger door window from the drivers switch. I replaced the 2 switch unit in the drivers door but still no luck. I bought this project truck about 6 months ago and it came like this, don't know the history. Any help would be appreciated, thanks in advance.
Old Mar 12, 2005 | 11:32 AM
Peter94's Avatar
Peter94
Check your wiring. That is going to be your problem, either at the drivers side switch, or the passenger switch. Most likely the passenger switch. Everything must be connected for both switches to work properly. By the way, where did you get your switches? I've been looking everywhere, the only thing i can find is the ones at autozone that are made for chevy, but they do work.
Old Mar 12, 2005 | 12:44 PM
864x4stepside
got the switches at local ford dealer, his last 2
Old Mar 12, 2005 | 01:31 PM
Peter94's Avatar
Peter94
how much did he charge you for them if you dont mind my asking, i believe the ones at autozone were like 15/20 bucks
Old Mar 13, 2005 | 10:15 AM
864x4stepside
about 20 for the driver and 12 for the passenger, looks like my problem is going to be in the bracket the door switches mount to, Ford no longer makes this item, guess I am off to the junk yard....
