Another booster threat- it's worth your time!
I have been putting together a list of brake booster part numbers to better understand all the types and interchangeability. I am working with a manufacturing company to create these boosters brand new once again. It seems that these are not available anywhere- the only thing I can find for a lot of them online is a return and rebuild service.
There are 12 boosters on this list and I am guessing that just about every model of ford truck can be served without actually recreating all 12. There is hopefully some interchangability. It costs a few thousand dollars per each part number to begin manufacturing.
I am hypothesizing the following things- if you have knowledge one way or the other on this list, please chime in:
1. Generally, there were boosters with three main types of rods/clevis (the part that connects to the pedal) - a long straight one, a short straight one, and a tear drop shaped bent one.
2. The teardrop shaped bent rod I understand to almost exclusively come in a longer form on F series trucks. There is a shorter version teardrop style rod but it was mostly on e series vans.
3. Of these three styles of boosters, there is a single or dual diaphragm version. the two diaphragm types are interchangeable on a truck that would have come with either type (where there is sufficient physical room)
4. Master cylinders will interchange between nearly all of the brake boosters- at least mount up, not necessarily be correct for the type of drums/discs, etc.
5. the 1976- 1977 bronco brake booster is not interchangeable with any of the F series boosters.
6. I think 6 versions of boosters could serve nearly all F series dentside trucks- a single/dual diaphragm for each of the three types mentioned above.
7. with the exception of D7TZ2005A, there are not online sources for purchasing these boosters outright, without a core.
Any input would be greatly appreciated, these trucks deserve to have good brakes available to decent prices!
Do the 3/4 and 1-tons have larger bores?
According to a search on rockauto, it looks like 1974 F250s could have come with either a 1" bore or a 1.25" bore master. interesting!
I've been running it for 5yrs, it will still throw you into the dash. I do have a 79 suspension in a 66 F250 and drive 5-10K mi a year. Can't imagine it being better.
I sure hope you have success with this venture!
I am trying to get a new booster for my truck right now...... LUCKILY..... I have found the one that seems to be a replacement for the one that came out of my truck.
All I have to go by is the shape, the length and look of the rod. (It is the 4" short straight rod).
Mine seems to match the Cardone #54-73703 you list on your chart above. Your chart has now given me a boost of confidence! THANKS!!
I agree with gashog, i would like to have a dual diaphragm booster for my 77 F-150 4X4. Please keep us informed of the progress on these! And Thanks!! -Ed
