Problems after changing fuel filter
Old Aug 23, 2020 | 09:57 AM
pirschwagon's Avatar
pirschwagon
Originally Posted by Dan V
What @pirschwagon is getting at ( I think), is that some aftermarket fuel filters come with a new cap as part of the filter. And on the bottom of the cap there is a molded pin (protrusion) that opens the center of the standpipe by pushing it open as the cap is tightened down. On some aftermarket caps that pin isn't of the length to properly open the standpipe.
You are correct. That's where I would start. O.E.M.
Old Aug 23, 2020 | 10:42 AM
Me zac's Avatar
Me zac
Is attached to lid
Old Oct 13, 2020 | 03:32 PM
Me zac's Avatar
Me zac
Solution
It ended being the ICP
Old Oct 13, 2020 | 05:28 PM
brian42's Avatar
brian42
Veteran: Navy
Thanks for coming back and posting your results.
How did you figure out it was your ICP sensor?
Old Aug 31, 2024 | 11:39 AM
marksman76's Avatar
marksman76
Guys/ Gals my Motorcraft source quoted me about $61.00 the other day for the Fuel bowl filter .
I used to pay about $45.00?
Motorcraft part number FD - 4596 aka Ford part number F81Z - 9N184- AA
I know others here on FTE are using aftermarket filters and beveled gasket .
Info, links, part numbers would be nice.
Thank you all!
Old Aug 31, 2024 | 12:39 PM
Socket's Avatar
Socket
Thank you all!
https://www.riffraffdiesel.com/oem-fuel-filter-99-03/?srsltid=AfmBOoo0vqVaDy-CwrTaaGLVmqKcPV-3GT-gcRyI7f0BPgEG99_iRPMBTy8
This is what I’m buying now.
I also run a different fuel bowl lid O Ring. There was a thread in the FAQ about it and I’m happy with the results so far.
https://www.mcmaster.com/product/90025K557
Old Aug 31, 2024 | 02:24 PM
marksman76's Avatar
marksman76
I was just looking through the tech folder.
Seems the Diesel Fuel Lubricity additive chart may have a mistake?
Note line 4 Opti-Lube Summer blend; ratio shows 3000:1
All the other choices are much smaller ratio?
https://cimg0.ibsrv.net/gimg/www.for...c1f58ab9ad.jpg
Old Aug 31, 2024 | 10:11 PM
Eman85's Avatar
Eman85
Rock Auto Wix is $28 Motorcraft $49
giorgio.fo
Feb 6, 2017 10:43 PM
gbeach
Sep 15, 2015 02:16 PM
97REDPSD
Nov 30, 2007 01:05 AM
piper350
Bio-diesel, Propane & Alternative Diesel Engine Fuels
May 6, 2007 06:55 PM
janos
Jun 8, 2003 09:51 AM
