gas guage
Old Oct 20, 2003 | 03:35 PM
tabledancer's Avatar
tabledancer
Question gas guage
hi everybody, I am having problems with my gas guage reading to high, in other words with a full tank it reads off the scale to the rite and when it shows 1/4 it`s dry and I`m walking,also after taking it out of storage in the spring{sleeps all winter}the guage refuses to work at all till it gets at least 2 tank fills to drink.thanks for any help. Tabledancer
Old Oct 20, 2003 | 07:51 PM
Mil1ion's Avatar
Mil1ion
The gauge pinning to the right mean too much Ground (no resistance), the sending unit is out of whack from corrosion or it is failing.
Old Oct 21, 2003 | 12:39 AM
tabledancer
Mil1ion,Thanks a bunch for info,guess I`ll do that this winter,lot work scheudled,that sending unit is on the tank,rite!!! T.D.
Old Oct 21, 2003 | 12:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
Ahem, the gage pinning to the right means that you have a faulty instrument voltage regulator or a short in the fuel sender wire (intermittant or resistive or your gage wouldn't read at all).
If you ground the fuel tank sender wire it will peg to the right and burn out fairly quickly...
The IP voltage regulator can develop a high resistance connection to ground on its power supply and it will put out too much voltage causing your gages to read high. This is the most common failure mode but it is easily fixed by cleaning the contacts and adding some dielectric grease.
Do you have gages or idiot lights?
Are all of your gages reading high?
Old Oct 21, 2003 | 03:03 PM
tabledancer
I have gauges but only the gas gauge is used,I have separate oil pres.voltmeter,and temp.all sw mechanical.Thanks for the info T.D.
Old Oct 21, 2003 | 05:39 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds like cleanup time for the IPVR...
Kelloyan
Jan 24, 2013 06:52 PM
forddude66
Aug 9, 2012 10:21 PM
Skydmark1
Feb 26, 2009 07:56 PM
96eddie5.8
1978 - 1996 Big Bronco
Jul 10, 2007 04:26 PM
tcb89
Mar 1, 2005 02:58 PM
