V-10 Fuel System Problems
Old Oct 20, 2003 | 03:22 PM
Wyobuilder's Avatar
Wyobuilder
Ok,
I have a 2001 Excursion with the mighty V-10 and 46,000 miles. About a week ago i started having acceleration problems. When traveling down the road it would bog out when i hit the gas. If i put it in neutral, turned off the key, turned it back on and continued on my merry way it would work fine for another 5 to 10 miles then would do it again.
I had a mechanic buddy replace the fuel filter, thinking that was the problem, but no dice.
Does anyone have a suggestion before the wif gets in the family truckster and this happens to her. I don't think i can take another *** chewin.
Thanks for any suggestions
Old Oct 20, 2003 | 03:47 PM
Landyot's Avatar
Landyot
My best guess (after the fuel filter) is you got a bad tank of gas. Run that tank through as close to empty as you dare, and try another tank from elsewhere. I AM NOT suggesting you use a higher octane than what the manual recommends ... just a different source.
I've had filters clog on me, and your turning it off & restarting procedure sounds like the typical short-term solution. When you turn it off, that allows the dirt particles that were being sucked/pushed against the filter element to fall via gravity. And after driving a bit more later, the fuel in the filter churns up those particles again, clogging the filter.
In fact, if you've already replaced the filter on this one tank of gas, it may have become contaminated (from a bad tank of gas), and might need replacing once again.
Like I said, that's my best guess. Anyone else have other suggestions?
Ken E.
Old Oct 20, 2003 | 04:36 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Ken always has some great advice, so I'd go with what he said to do first. My guess is that you may have dirty or clogged fuel injectors. If you run a few bottles of injector cleaner or fuel booster through 1 or 2 tankfuls, that might solve your problem.
Anyone else with a few suggestions?
Old Oct 20, 2003 | 05:00 PM
Landyot's Avatar
Landyot
Toreador_Diesel - Thank you, sir, for the kind words. I just say what seems logical to me ... or if it's a subject with which I have a little experience. I really don't know anything, and I can prove it, too! (ha-ha)
My "bad gas" situations have always involved (believe this or not) Exxon fuel. I've had the worst luck with their stuff, and have avoided it like the plague. And more odd? The el-cheapo gas stations around here have never given me any problems.
And the worst fuel I've ever encountered was during my trips to CA. That reformulated junk is just that junk. Those left-coasters are sold on it though, because of the claims it pollutes about 20% less than other fuels. But my mileage dropped dramatically from using it, and I ended up burning almost twice as much fuel as normal. (That's right! My vehicle went from 30MPG to a little over 16MPG while in CA! Returned to normal upon leaving CA.)
Let's see now .... If I'm burning twice as much gas, but it pollutes 20% less .... (calculating here) .... I've increased my pollutants only what? 60%? I just love false economies.
Old Oct 20, 2003 | 05:36 PM
Wyobuilder's Avatar
Wyobuilder
Thanks for the input guys.
I know that bad gas can cause some of these problems, but i can't help to think that it may be computer related. I am no mechanic in any way, shape, or form, but i do know that if there is a computer glitch, one of the ways to reset the computer is to turn the truck off, and then on again.
The only thing that makes me think that it may be this or something else is because this has happened on the Interstate going 70 mph. I shut it off while still rolling along, and then restarted and everything was fine again. I couldn't imagine that the 3 seconds the thing was off would allow the particles to sink.
Anyway, i am having the filter removed and blown out as we speak. So hopefully something shows up in the filter which would solve this problem.
BattleWagon79
Dec 12, 2024 08:54 PM
Lollygagger
Jan 26, 2012 09:04 PM
hamling
Dec 31, 2003 08:19 PM
GAV10
Apr 2, 2003 07:51 PM
