285 or 295s?
Old Oct 12, 2003 | 11:57 AM
bigdawg460's Avatar
bigdawg460
285 or 295s?
I decided to go with bfg ats,but now i dont know if i should get 285-75-16s or 295s.
Old Oct 12, 2003 | 04:04 PM
MN_Wild's Avatar
MN_Wild
I was going to do the same thing but I am wondering if it will fit in the garage with the bigger tires. Anyone???
Old Oct 13, 2003 | 02:40 AM
Monsta's Avatar
Monsta
Sit. Stay.
I vote for the 295's.
As far as it fitting in the garage...how much taller is the 295 vs. the 265 tire?
Just add the difference to the height of the truck and measure your garage door to see if it'll still fit.
Old Oct 13, 2003 | 07:12 PM
spartan's Avatar
spartan
The 295 BFG AT is a 33.5 inch tall tire - go from there.
Old Oct 14, 2003 | 02:14 PM
xbox's Avatar
xbox
I have the 285 BFG ATs and it still fits in my garage. I have standard size door openings (7') as well.
Old Oct 14, 2003 | 07:45 PM
pancartom's Avatar
pancartom
i've got a 250 SD with a 2" leveling kit in the front with 315's and it still fits in my 7' garage door, and in every parking garage that is marked at 7' max.....
Old Oct 19, 2003 | 07:24 PM
Crumm's Avatar
Crumm
I am in the process of ordering a 4" lift and installing 315's. I will have about 1" clearance to get into my garage. What I did was take a 4' board a level and a tape measure. Lay the board on the highest part of your X (on mine it was the rear spoiler). Set the level on the board so you have it level and measure the distance to the ground. Then measure your garage door and see how much you have to play with.
Old Oct 20, 2003 | 03:33 AM
Monsta's Avatar
Monsta
Sit. Stay.
Originally posted by Crumm
...(on mine it was the rear spoiler). ..
You have a (bling) spoiler on your (bling) Excursion?
Can't be...I must be thinking of something different.
Old Oct 20, 2003 | 08:17 PM
Crumm's Avatar
Crumm
I suppose I used the wrong term. It is the plastic wind deflector mounted on the rear of the roof above the rear door. I believe it is to create a wind current that is suppose to keep the rear window clean although it does a poor job of it. I believe that most X's come with them from the factory.
