1978 - 1996 Big Bronco
steering stabilizer question
Old Aug 14, 2020 | 05:22 AM
hayden01's Avatar
hayden01
I found the other threads relating to this topic and I picked myself up a Monroe kit. Know how to install it but had one question:
Did you guys have to drill out the preexisting holes in the passenger side frame or just get smaller diameter, grade 8 hardware?
I'm worried if I go with smaller diameter bolts there would be slop in the bracket no matter how torqued down the bolts are. Therefore lessening if not nullifying, the effects of the stabilizer altogether?
So ultimately the question is to drill out the frame holes or smaller diameter grade 8 hardware at least through the frame?
Old Aug 19, 2020 | 05:46 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What problem are you trying to cover up by installing one of those?
Old Aug 19, 2020 | 06:04 PM
hayden01's Avatar
hayden01
none. ive alredy taken care of the front end, and steering issues. just trying to add to highway stability.
Old Aug 19, 2020 | 06:09 PM
My4Fordtrucks
I put almost 300K miles on my ‘87 without the need for a steering stabilizer. If the alignment is right it should be plenty stable at highway speeds.
Didn’t the kit come with the required hardware and instructions?
Old Aug 21, 2020 | 11:54 PM
greystreak92's Avatar
greystreak92
Gotta agree with My4Ford on this one. Stabilizers are just a way to make conventional steering feel like rack & pinion. More effort to steer with nothing done to actually improve handling. And the TTB axle is gonna bump-steer in severe off-camber situations no matter what you do to it. But on-road and even at highway speeds its steady as a rock... unless it has something loose, broken or worn out. Not telling you not to install it, but it isn't going to do what you think it will.
BigBlueX
Feb 3, 2016 03:34 PM
Nor Cal ford
Oct 27, 2004 11:19 AM
loui6035
Dec 22, 2003 06:10 PM
starweb
Nov 22, 2002 07:36 AM
