Steering Box Question
Old Nov 22, 2002 | 01:30 AM
starweb's Avatar
starweb
I have wrote before about to much play in my steering. when I start the engine and move the steering wheel left to right, I noticed that there is some movement in the steering box. since it is bolted in should it move at all?
Old Nov 22, 2002 | 01:57 AM
heathdaily's Avatar
heathdaily
If the box is moving in relation to the frame that's a problem. Sometimes the bolts back out. Sometimes the frame cracks. A frame can be patched but unless done properly it's a weak spot for future failure. If it's the bolts just clean up everything real good and re-install with some lock-tight. Take the time to inspect everything and make sure nothings gonna fubar at 60+ mph on you later. New fresh bolts may be necessary.
Old Nov 22, 2002 | 07:36 AM
glenb's Avatar
glenb
