oxil
Old Aug 12, 2020 | 10:59 AM
oxil's Avatar
oxil
oxil
getting ready to install hood on my 47 1/2 ton, should I attach the hinges to the hood first or the body? and there are four holes in the body location, do I use upper or lower holes . I couldnt remember how to load pictures of it, guess I'll work on that next. Just moved it out of my corncrib for the first time in 4 years, lots of work to do yet, I'm the same age as it so I move slowbut steady. thanks for any response
Old Aug 12, 2020 | 11:48 AM
Rust Wrangler's Avatar
Rust Wrangler
Not sure about the four holes in the body location, as the ones I've done only had two on each side. I first install the hood hinge brackets to the cowl and leave them loose, so they can be adjusted and tightened up after the hood has been installed. Put a blanket across the cowl to protect the rear hood edge and top of cowl, then set the hood in place. Lift the hood up at the front and support it. Attach the hood hinge bracket arms to the hood, then attach the hood support arms (hinges). Hope this helps.
Old Aug 14, 2020 | 07:09 AM
oxil's Avatar
oxil
thanks for responding, I guess I was referring to the hood arm and spring assy, 2 holes on each side of cowl and cant remember which holes to use. all help is appreciated, thanks BobHatcher
Old Aug 14, 2020 | 11:58 AM
bernette's Avatar
bernette
i used those holes ,the rear ones are rubber pads to prevent rubbing.
iwanaflattie
13
Jan 22, 2011 01:40 PM
Kuskoal
Jul 20, 2008 01:58 PM
flysniper
Paint & Bodywork
Jan 9, 2008 09:13 AM
GubNi
21
Feb 13, 2006 07:06 PM
