Drag link options
Old Aug 11, 2020 | 04:15 PM
JimiT's Avatar
JimiT
Drag link options
I'm working on my 1965 F350,
My drag link joint that looks like a tie rod end is a bit lose, I cleaned and and greased and it is significantly better but not sure how long it will last. I did a forum search and there are no replacements for this item. It is item 3305 in the attached image, If it gets worse I was thinking of having it machined to fit a tie rod end as when I had it apart I tested the fitment of a spare tire rod end and i noticed to boot had the same P/N and my tie rod end fits perfectly it would seem. My concern is that I would change one end to have the end that attaches to the pitman arm crap out. Any other ideas/solutions for this? Does any other drag link fit, I am fine with minor modification to make it work.
My second question is I have been noticing that when I drive the old 1 ton it feels like I'm dragging a parachute. It has been tuned up, new plugs and wires, distributor cleaned and points set, compression is 149-152, fuel system operating perfectly, no knocking or irregular noises in the engine. Brakes are not dragging. I am having the timing check in a day or so and going to get the exhaust checked Friday as well, one muffler seems to sputter a bit. Anyone have any other ideas. I was hauling wood today and even loaded climbing a hill it would accelerate and has no problem maintaining speed. But as I push the pedal it just feels like I'm dragging something, no stubble or sputter just feels not quite right. I know it's not a mustang but seem like something is amiss.
Old Aug 12, 2020 | 03:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Basic part number for a drag link could be 3304 or 3305. In this case, it's 3304.
C1TT-3304-AH .. Drag Link / Obsolete
1961/66 F250 4WD with 3,500 lbs. capacity front axle & F350.
OBSOLETE RELIABLE PARTS in Nashville GA has 1 = 229-686-5101.
B5TZ-3A533-A .. Drag Link Ball Stud Repair Kit / Parts with black dot in your pic // Obsolete
1953/66 F350 // 1948/52 F4/F5/F6 & F5/F6 Cab Forward // 1953/56 C500/600 & F500/600.
CARPENTER NOS PARTS in Concord NC has 1 = 800-476-9653.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
KLIMESH MOTOR SALES in Calmar IA has 3 = 563-562-3241.
Old Dec 15, 2020 | 09:22 AM
JimiT's Avatar
JimiT
Any alternate drag ling for this. I'm at the point where I may cut the bad end of and replace ( have a machine shop sleeve or tap and thread it) it with a tie rod end which is the same size. Has anyone else done this? is the tube hollow or solid?
Old Dec 15, 2020 | 11:05 AM
BobbyFord's Avatar
BobbyFord
C1TT-3304-AH in-stock now | Ford Parts Locator (rearcounter.com)
Old Dec 15, 2020 | 02:35 PM
JimiT's Avatar
JimiT
I called although it shows in stock online they have none in stock, seems to be a extremely rare part.
Old Dec 15, 2020 | 04:35 PM
JimiT's Avatar
JimiT
Anyone else ever make mods or figure out a better way to deal with this. maybe change the pitman arm and drag link all together with something else. All ideas are appreciated.
Old Dec 16, 2020 | 08:29 AM
BobbyFord's Avatar
BobbyFord
Maybe ask Moog if they’ll make something for you.
https://www.moog-suspension-parts.co...?vehicle=16375
Old Dec 16, 2020 | 12:58 PM
third66go's Avatar
third66go
Call Dennis Carpenter Co., and ask for the NOS truck parts guy. They have a stash of parts that are not in the normal catalogs, some not even inventoried.
Worth a shot...
Old Dec 17, 2020 | 03:49 PM
62SY4's Avatar
62SY4
Keep watching ebay if you want a new one. I bought an aftermarket (TRW) unit a year or so back, they do pop up from time to time.
Watcher58
Apr 11, 2015 07:29 PM
rmcgraw351
Aug 25, 2013 10:55 PM
460 FORD MAN
Aug 12, 2013 04:43 PM
fixnair
Dec 15, 2010 11:23 PM
