Rear Diff and Limited Slip
Old Aug 11, 2020 | 01:04 PM
akblackfoot's Avatar
akblackfoot
Have a pinion bearing whining so I'm taking it in to have it rebuilt. Decided to have them do a Eaton Detroit Trutrac rather than rebuild the clutches for the limited slip. Anybody done this and what's your experience?
Old Aug 11, 2020 | 04:31 PM
akblackfoot
Also wondering if there is anything else I should have them check/replace while they are in there?
Old Aug 11, 2020 | 10:39 PM
AK4x4's Avatar
AK4x4
Sounds like a good plan, I would have them check the entire rear drive-line (axle & drive shaft). For axle lube I prefer the Amsoil SEVERE GEAR 75W-140. I don't know where you are planning to take it, but I would recommend Young's Gear. Good Luck , Russ
Old Aug 12, 2020 | 12:32 AM
akblackfoot
Yep. Taking it to Young’s Friday. Eaton says not to use synthetic with the Truetrac? I have AMSOIL 75w-140 in there now.
Old Aug 12, 2020 | 03:37 AM
npccpartsman's Avatar
npccpartsman
I've got almost 200K on my Truetrac and it's been flawless. Use the recommended lube in the TT and save your hard earned $$$ for something else. Eaton has a reason for what they recommend and why. Email them if you have questions.
Old Aug 12, 2020 | 11:46 AM
akblackfoot
So no concern about the rest of the bearings and gears being that Ford recommends full synthetic in the differential? What interval should I be changing the diff fluid with the non synthetic and the TT in there?
Old Aug 12, 2020 | 02:16 PM
Motohead911's Avatar
Motohead911
This is directly from the Eaton website application page,
Detroit Truetrac A quality petroleum GL5 rated (mineral) based oil is recommended. Synthetic oils may also be used if desired per axle manufacturer’s recommendations. Friction modifiers should not be used however, as they will decrease overall performance (reduce differential bias).
Bronc1
2009 - 2014 F150
20
Apr 27, 2014 07:47 AM
afonda
Dec 19, 2008 07:55 AM
markn455
May 25, 2006 02:51 AM
Oil-Pig
Jan 13, 2006 09:30 AM
spr1049nc03
Jul 9, 2003 07:54 AM
