I picked up a set of factory sway bars and mounts from the junkyard to swap them onto my 1995 F150 that didn't come with them. I measured the diameter of both bars and they are both 7/8". I can find front sway bar bushings in 7/8", but seems that no one makes rear bushings in 7/8". What's the deal?
Your front and rear sway bar use the same bushings. Both of your sway bars is connected by 2 mounting brackets near the middle of the bar and then they are connected by an eye link at the ends of each bar.. front and rear . Get you some polyurethane bushings.
And I'm pretty sure that the 2 main brackets near the middle on each sway bars came in different heights. Make sure the bushing is the correct height for your bracket.
For future reference, rear bushings for a 7/8" sway bar are Moog K8651. They are not listed for this application, not sure why. Front bushings for a 7/8" sway bar are Moog K8791.
