Gear Oil Question
Old Aug 9, 2020 | 06:46 PM
rcorcich's Avatar
rcorcich
Gear Oil Question
HI,
Truck is a 2011 F-350 6.7 4WD, dually diesel.
The tag on my rear axle differential cover says : 3.73, BC34-MD , 2013832-5 , LS . I know its a 3.73 Limited slip rear.
I think it's a Dana M80 rear but i'm not sure. Door pillar sticker says Axle code is 3L.
Could some one tell me for sure what rear it has, I need to buy Gear oil for it and not sure which one to buy.
Thanks
Rich,
Old Aug 9, 2020 | 08:24 PM
Just Strokin's Avatar
Just Strokin
Your LS uses clutches, you will need to add a bottle of friction modifier to the gear lube. DRW is the Dana M80. SRW is the Sterling 10.5".
2011 Owner Manual
https://www.fordservicecontent.com/F.../11f23og4e.pdf
Old Aug 9, 2020 | 08:45 PM
rcorcich's Avatar
rcorcich
Thanks , got it,
I didn't see where it said single rear wheel for the Sterling or dually for the Dana M80 and they both list 350's so I thought i would this great community of knowledge before I made a mistake.
Many thanks,
Rich
Old Aug 10, 2020 | 05:05 AM
senix's Avatar
senix
Super 80. I used Valvoline in mine, Had the friction modified in it and worked well.
Buy some RTV, there is no gasket when you do the job.
Old Aug 10, 2020 | 05:38 AM
Overkill2's Avatar
Overkill2
Lube Locker makes a reusable gasket for the 80. I have their gasket in my Sterling 10.5. No leaks since changing mine 21k miles ago.
https://www.lubelocker.com/products/dana-80-llr-d080
Old Aug 10, 2020 | 08:10 AM
rcorcich's Avatar
rcorcich
Hi,
I'm not doing a drain and refill , just topping off the rear because i'm replacing the rear rotors and I lost a little bit in the process.
Old Aug 10, 2020 | 12:04 PM
Overkill2's Avatar
Overkill2
Alrighty then. You have it for future reference then if you do decide to buy one when or if you decide to drain and fill your diff fluid.
Old Aug 10, 2020 | 12:07 PM
rcorcich's Avatar
rcorcich
Thumbs up
Thanks All ,
Old Aug 13, 2020 | 08:53 AM
speakerfritz's Avatar
speakerfritz
Originally Posted by rcorcich
HI,
Thanks
Rich,
also check to see if you need ford limited slip additive
Old Aug 13, 2020 | 11:12 AM
Overkill2's Avatar
Overkill2
And if your diff needs it, when you change it, look and see if the gear oil you have or will buy, already has it in the oil. That's the easier solution.
cris.phoenix87
Sep 26, 2017 08:38 PM
mojavearcher
Jan 24, 2017 06:24 PM
devolic
Mar 30, 2010 07:08 PM
davE350
Oct 16, 2007 07:28 AM
jake98
Jan 31, 2005 09:50 PM
