Workaround on power steering
Old Aug 9, 2020 | 11:42 AM
Olblack's Avatar
Olblack
Hello all Olblack is a 1976 F-250 .After dumping atf n hydrologic oil all over my drive for tooooo long . The pulley on the power steering pump got spun off the pump. I’ve been using it like that and prefer it now. What does it take to just get rid of the power steering out of the current oem system ? Right now the system is still sealed essentially with just the belt n pulley off. Should I try to bypass the control pump? The seal on the power assist ram has worn down the surface of the assist ram also . Not sure if trying to bypass these units and connect the hoses together.
My goal is to remove what I have to from oem PS ( ****** Of **** ) unit . And go old school. Thanks man
Old Aug 9, 2020 | 05:53 PM
Christmas's Avatar
Christmas
You will need a manual steering box, no way around it.
Old Aug 9, 2020 | 06:55 PM
ford390gashog's Avatar
ford390gashog
He already has one in the truck. The PS assist was just that, he can replace the ram with a regular link and be done.
Old Aug 11, 2020 | 06:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
OP already has it!
1973/77 F250 4WD High Boys have Power Assist P/S that use the manual steering gear box, because it has nothing to do with the Power Assist system.
Old Aug 12, 2020 | 09:29 AM
Olblack's Avatar
Olblack
Thanks, so I can just replace the assist ram on the axle with the non hydrologic ram. Looks like a shock absorber ?
Ripcity
Sep 14, 2013 09:08 PM
Randy Jack
45
Jun 30, 2008 07:14 AM
wayneasbell
Aug 8, 2006 08:43 AM
