Power steering gear box with pit man arm from 1968 - 1979 F150's will interchange on your truck. Perferable find the PS box off an 1973 -1979 F150's.
Find a donor truck at a wrecking yard and get the:
Pulleys, for the harmonic balancer.
Power Steering (PS) bracket, bolts, & PS pump.
Power Steering hoses from PS pump to PS gear box.
Some truck will have a PS cooler line, it will help to keep the PS fluid cool.
Will need to swap the steering column and shaft with one off a 2wd truck with power steering.
-or-
If a certified welder can fabricate a shaft to the gear box.
Flush out power steering system.
When buying used part, one never really knows the true condition of the used parts. And most likely will need to replace PS hoses, PS pump, or PS gear box.
