Off road build
Old Aug 8, 2020 | 12:37 PM
blueoval65's Avatar
blueoval65
Off road build
I got my eye on a couple Expeditions to do some mild off road/ overland. I was wondering which generation Expedition is generally more off road capable.(gen1 97-02 or gen2 03-06) I would start barely more than stock and slowly make mods to be a better trail rig. I was just curious which is better out of the box.
Note: I know a Bronco would be a better rig, but every Bronco for sale around here is made of gold. I can get in an Expy for under $3K and start wheeling.
Old Aug 8, 2020 | 08:22 PM
Spaznaut's Avatar
Spaznaut
The early models with the solid rear axle will take a little more lift than the later Independent rear. Also check the wheel options as they changed from 5 to 6 lug later on. The later models (not sure when) have the 2wd option instead of awd as the base selection. There are some that are heavily modded. You may check the expedition forums for some nice builds. www.expeditionforum.com I'd just look for the best solid foundation and build it up.
Old Aug 9, 2020 | 07:48 PM
Travis S's Avatar
Travis S
97-98 have 2wd as an option on the transfer case switch, 99+ is A4WD. Generally speaking, First Gens (97-02) are more akin to their F150/Bronco siblings, while Second Gen (03-06) is a bit more "soccer mom".
This might give you some ideas on how to perform your intended modifications correctly and cleanly: https://www.ford-trucks.com/forums/1...tor-f150s.html
I tend to be VERY picky about how I do any mod, such as the 5-Switch mod for the Overhead Console which uses regular power window switches for the extra switches. As a result, every mod I do is overbuilt and underworked and will last forever.
SproutW
Mar 9, 2006 11:25 AM
amm888
Feb 4, 2006 03:22 PM
00_F150
1978 - 1996 Big Bronco
Apr 2, 2002 01:15 PM
ricciardelli
Sep 2, 2001 08:47 PM
