engine stalling at idle after choke opens
I recently nabbed a '69 ranchero with a 250 cid inline 6 cylinder. 69000 miles on it. Autolite 1101 carb.
Car runs decent, but only with the choke half closed. Fires right up and idles on fast idle, but as the thermal choke works it's magic and begins to open the choke, it starts stumbling and eventually dies. So if I want to drive the car I have to over-torque the thermal choke spring so that when the spring is fully relaxed it's still holding the butterfly valve at about 50% open. This works but the performance is obviously not great.
Here's what I've done:
1.) Completely replaced the carburetor and gaskets and reset it to specification (float level, accelerator pump, idle mixture, etc etc.) This did nothing but hey at least I have a new clean carb.
2.) Sprayed wd-40 all around carb and intake spacer to search for leaks, didn't see anything...
3.) New fuel filter
4.) Replaced the fuel pump and pump-to-carb fuel line. The orignal fuel line was dented a little so I thought a full replacement would help. It didn't.
5.) New spark plugs - previous ones were pretty gnarly looking when I pulled them out.
6.) New PCV valve
7.) Plugged ALL VAC LINES off the carburetor to see if I could isolate some sort of vacuum leak, this did nothing.
8.) Compression Test - performed with all plugs in place, throttle not open. I figured out later I should remove plugs and hold open throttle, but here are the numbers nonetheless.......
#1: 140,
#2: 135,
#3: 100,
#4: 145,
#5: 145,
#6: 150
*It's obvious the compressoin of #3 is pretty low. But would this be enough to cause the problem I'm seeing with the choke?
My next steps are to replace the points breaker because it's looking a little worn, and the condensor while I'm in there. Also replacing the spark plug wires. Need to check double check timing, too, just haven't yet.
These are all relatively cheap fixes, that's why I'm doing it.
Trying to do everything I can within my ability before taking it back to the mechanic with my tail between my legs.
Does anyone else have any ideas why this may be happening?
THANKS!!!
So far I've been putting only ethanol free gas in it....not sure the octane rating of the ethanol free stuff.
I'll definitely follow up with a post after I set the gap and get the timing right.
Any thoughts on that one cylinder with low compression?? That has me worried...
I did a little digging in my old Cylmer book as my dad use to have a 1969 F100 and sure enough i found it! You are right...the point gap for the 250 I6 is .025 but the dwell angle range is 37-42 degrees... the 240 CID gap is listed at .027.... so I would 1st make sure the gap is correctly set at .025... if that doesn't make any difference, then I would check the dwell or just adjust the gap out to .027... but my real instinct is the initial timing needs to be bumped up a bit and the fuel mixture needs to be adjusted (ie richened up a smidge)
I'll report back with my findings! I know I always like to see the conclusion when people are describing these sort of issues.
Turns out the low compression on cylinder 3 was due to a leaking exhaust valve...Took her to the shop and they did a leakdown test which let them pinpoint the issue.
So they removed the cyclinder head and re-surfaced the valves and replaced valve seats, etc. Fresh coat of Ford "Corporate Blue" on the cylinder head and she's running so much better now with a lot of improvement in acceleration and idling.
Also the shop discovered that the "refurbished" AutoLite carburetor I installed was faulty. We weren't sure exactly why, but we ended up using the base of the refurbished carb and the top half of the original carb to get a good running condition! So beware when ordering rebuilt or refurbished carbs as they don't always work as expected - most of you folks probably already are weary of that.
Oh and now new problems arise of course....newish aluminum radiator loosing coolant somewhere which wasn't an issue before....gah! The shop installed a new thermostat which I may be removing....we'll see....
Congrats!!!! You are getting there!
If you know someone who has an ignition oscilloscope they are really good at sniffing out defects in wiring, or distributor, bad condenser, all kinds of stuff. Deploying Ye Olde Parts Cannon is dangerous these days because the ignition parts are so crappy.
Don't worry too much about compression, get the shop manual and give it a good Tune-Up. You have a good baseline now, excessive cylinder or ring wear causes low compression but oftentimes it is due to stuck rings due to gum and varnish. A solvent can really help with this. Couple that with some highway runs, make sure it's got a good factory temp thermostat (Autolite surplus is your friend here too) installed and reaches normal factory temps and I bet the compression numbers will improve and/or equalize.
