help - emissions systems delete now what ?
Old Aug 6, 2020 | 01:15 PM
Franklin2's Avatar
Franklin2
If the distributor and carb have been changed, you are good. All that other stuff is just dead weight now. I saw your video, I think I would pull the carb and go through it.
Old Aug 6, 2020 | 04:47 PM
FuzzFace2's Avatar
FuzzFace2
Just to make sure you have non-feed back carb & dist. post up a picture of the dist. and a few of the carb with the filter housing off.
Then as DaveF said the carb may just need a going thru.
I also asked if the choke was opening all the way when the motor is up to temp.
We will get this to run good again for you.
Dave ----
Old Aug 6, 2020 | 11:27 PM
85e150's Avatar
85e150
Two threads, different info.
To the OP: It's best to get all the cards on the table in one thread.
https://www.ford-trucks.com/forums/1...m-exhaust.html
Old Aug 7, 2020 | 07:05 AM
Franklin2's Avatar
Franklin2
Two threads, same theme, rebuild the carb.
myoldf250
Jul 24, 2013 10:04 AM
ToddGatman
May 3, 2013 08:55 PM
Brandonsf250
Aug 28, 2012 12:25 PM
Ford51
Texas Chapter
Oct 12, 2005 12:35 PM
