1986 E350 Hard Start
Old Aug 4, 2020 | 04:14 PM
verbatim68's Avatar
verbatim68
I have the exact same problem as stated in the thread below.
https://www.ford-trucks.com/forums/8...ard-start.html
To quote the original post from this thread:
Originally Posted by docpec1
Hi.
I'm new to the fourm and hope to obtain some help. I have a 1987 E350 460CI engine RV with a carb. My problem is this:
If I let the RV sit for, say a week, I have to pump the gas pedal many, many times and grind on the starter 7 or more times (about 15 seconds each time) to get the engine to start. Once started, I have no problems. It will start right away next time, unless I let it sit for a couple of days. Then I have go through the same ritual again.
I don't have the vehicle available at this time so I don't know if it has an engine mounted fuel pump or not. I do have 2 fuel line running under the vehicle so I may have an electric fuel pump.
Do carb. model engines have electric fuel pump?? Could I have both electric and engine fuel pumps ?? Please advise. Thanks.
Doc Paul
I'm not going to retype my symptoms because they are exactly the same. My questions are:
1. Is the advice of adding a pushbutton to jumper from the battery side of the solenoid to the fuel pump side of the starter solenoid to allow priming of the carb a valid fix for this problem? The original poster didn't state whether it solved the problem or not.
2. If the answer is yes, can someone tell me how to identify the fuel pump connection on the starter solenoid? I haven't looked at it yet, it's in a different yard, but just hoping for some guidance before I get there.
3. What size fuse inline with the switch?
4. What's the cause of this hard starting? Obviously, fuel is draining back out of the bowl into the tank. Do I need to rebuild the carb or is it something else?
Thanks in advance for any and all help.
Old Aug 5, 2020 | 04:52 PM
verbatim68's Avatar
verbatim68
I actually tried the fuel pump prime trick today and it worked like a charm. going to install the dash switch for now, but going to do a carb rebuild or swap out. Can anyone tell me the rebuild kit number for Holley LIST 50260-2 datecode 0726? The list number doesn't work on Holley's lookup page. What about replacement carb numbers?
rfurgy
Nov 15, 2010 01:56 PM
docpec1
Oct 6, 2009 07:45 AM
DaleFromMissouri
Jun 30, 2009 09:14 PM
tylerbrowntyler
Aug 29, 2007 08:21 PM
fast_eddy
1978 - 1996 Big Bronco
Jun 17, 2002 07:31 AM
