Reverse level or +2.5 level?
Old Aug 4, 2020 | 09:07 AM
Mitch7c's Avatar
Mitch7c
Just picked up a 19 6.2 f250. Wanting to do something with how much rake I have.
I searched and found the PMF replacement blocks to drop the rear to only a 2” block.
or I want level the front with the ready lift 2.5” kit.
anyone had any experiences with both and what do you prefer?
mostly haul a flat bed trailer or a gooseneck cattle trailer but not all the time. The truck is already tall so I know I would be able to lower the back no problem but have never done that to one of my trucks before. Just trying to be different than what I have normally done.
thanks in advance!
also what size tires are you guys running with your setups? Pictures appreciated!
Old Aug 4, 2020 | 01:57 PM
First Dually's Avatar
First Dually
Originally Posted by Mitch7c
... The truck is already tall so I ...
What you said plus "gooseneck/fifth wheel" pretty much makes lowering the rear the best move.
Old Aug 4, 2020 | 04:46 PM
honda250xtitan's Avatar
honda250xtitan
if youre happy with ride quality as is, lower the back. Otherwise Carli or Icon coil springs make a big difference in ride quality and give you a nice 2.5" lift.
Old Aug 4, 2020 | 04:48 PM
ocwill11's Avatar
ocwill11
you also may want to measure it out yourself, 2.5 may be too high.. I have a 19 and it has the snow plow package and it is only 1.5 low in the front. I left it because it is not too bad in my opinion
Old Aug 4, 2020 | 08:11 PM
Joe T's Avatar
Joe T
Lots of metric tires between the stock 34 inch 20s up to around 35 inches.
As far as lift or lower i wouldnt want to go beyond 1 inch in either direction really. Since you said you are actually using the truck.
Old Aug 4, 2020 | 08:23 PM
ocwill11's Avatar
ocwill11
another reason I did not do anything, don't want to be nose high with weight in the back. I don't tow, but haul heavy loads on occasion....
tsmithco
Aug 23, 2021 03:50 PM
Kevin Clayton
Jul 4, 2020 10:02 PM
twesslen
Mar 30, 2017 08:43 AM
littleapple
Nov 30, 2015 07:18 AM
wb6anp
May 7, 2008 06:48 PM
