A wine or hum from engine area
Old Aug 2, 2020 | 05:58 PM
Brian Busse's Avatar
Brian Busse
2014 f150, runs perfect, but I went on a trip through the mountains when we had Temps in the 90's, and ever since then I have been having a wine or hum that comes from the engine area. It sounds more like a bearing going out. Could it be the idler pulley bearing? Or is it more likely something?
Old Aug 2, 2020 | 08:43 PM
gDMJoe's Avatar
gDMJoe
Lightbulb
Wine, eh? Sure it's not a whine?
More than likely it's something (?) associated with the FEAD (Front End Accessory Drive). Lotsa rotating parts there. Open the hood and try to isolate the location (even if if only a general location) of the sound.
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
Old Aug 2, 2020 | 09:36 PM
steve(ill)'s Avatar
steve(ill)
squirt a few drops of water on the fan belt and see if the noise goes away or changes.. If so, the belt may be worn or the tensioner loosing tension... If the noise continues then test the pulley bearings...
https://www.ford-trucks.com/forums/1...n-startup.html
Old Aug 7, 2020 | 07:07 PM
stephen.osborne1's Avatar
stephen.osborne1
I know earlier idle air control valve motors could whine. They could sometimes be cleaned out with brake cleaner or similar. If not it's an easy replacement.
villestrip
Jan 21, 2017 01:59 PM
abyars111
Feb 26, 2014 09:51 AM
f1001969mike
1978 - 1996 Big Bronco
Oct 18, 2012 05:07 PM
danimalmanimal
Feb 4, 2012 08:38 PM
3wildboys
Dec 21, 2011 08:05 PM
