DEF Injector line removal
Old Aug 2, 2020 | 03:45 PM
Rick Steinheiser's Avatar
Rick Steinheiser
Hi all. I was wondering if anyone can help with a quick question. I have a 2012 F250 with a 6.7. I’ve started getting error code D2048 several times per day. I decided to remove , test and maybe clean the DEF injector. So I’ve removed the two nuts holding the injector on but I’m not sure how to remove the fluid line from the injector. There is a 90 degree elbow further up the line from the injector with a white retaining clip. I removed that clip but the line still seems to be held on to the injector. I don’t want to break anything if there is some sort of spring loaded retainer holding the hose on or some trick to removing it that I’m not aware of. Can anybody help? Thank you in advance!
Old Aug 2, 2020 | 04:13 PM
Just Strokin's Avatar
Just Strokin
Reductant Injector procedure. From 2014 Workshop but should be the same as yours....
File Type: pdf
petepetersen
27
Jul 18, 2017 12:58 PM
genscripter
May 23, 2016 09:28 PM
1985L8000cat3208
Apr 14, 2016 02:23 PM
LSO1123
Aug 23, 2011 06:30 PM
64F260
Mar 16, 2010 03:28 PM
