Tailgate swap (another thread)
Old Aug 1, 2020 | 10:34 AM
dagwood57107's Avatar
dagwood57107
I've been searching through posts and havent been able to find any photos or definitive answer on tailgate swapping. I have an 82 f100 that someone stole my tailgate off of. I've read in several places I can swap in a newer style from an 87+. A junkyard close by has a couple for reasonable $$ but I cant actually see how the swap would go without have to weld on some nuts for the latch posts to screw into. Does anyone have any photos of doing this sort of swap or have specifics on how this would be accomplished??
Old Aug 1, 2020 | 11:04 AM
Franklin2's Avatar
Franklin2
My 1980 originally had metal straps. At some time they went to cables. Did your 82 have straps or cables?
Old Aug 1, 2020 | 02:38 PM
dagwood57107
mine had straps. I think they ditched the straps after 82
Old Aug 1, 2020 | 09:19 PM
Franklin2's Avatar
Franklin2
Never converted one from straps to cables, which you would have to do. Is there a way to take the tailight out and be able to get to the back of that area to put nuts and washers on the new components?
Old Aug 2, 2020 | 12:57 AM
dagwood57107
Yes and no. I could get one on easy enough, but I dont think I could get a wrench in there to tighten it. I thought I'd have to measure three times and spot weld a nut into place, which would kill any idea of being able to reposition the striker bolt for adjustment.
Old Aug 2, 2020 | 06:55 AM
Franklin2's Avatar
Franklin2
In some instances I have made small plates, welded the nuts to the plate, and then slipped it in place. If you weld two nuts on one plate, one bolt will hold the other from turning the whole plate. Or sometimes if you make the plate big enough, it will swing around and hit something and let you be able to tighten it. And using a plate will let you adjust it.
Old Aug 2, 2020 | 12:48 PM
dagwood57107
Oh thats an awesome idea. I'm not much of a fabricator and that never even occurred to me. Beings that I can get a newer style tailgate for $75, where an original style would cost me closer to $300 - well worth the little bit extra effort. Thanks for the advice. Once I have it installed I will post photos!
Old Aug 2, 2020 | 07:53 PM
jackietreehorn's Avatar
jackietreehorn
FWIW, the consensus is that the new Taiwan made tailgates are total crap and to be avoided. I find originals all of the time.
Old Aug 2, 2020 | 11:40 PM
dagwood57107
oh, yeah I meant newer style as in off a newer truck from the junk yard. I found a 88 f150 tailgate for $65 ($75 with all the parts off the truck). Minor surface rust, wrong color etc lol
Old Aug 3, 2020 | 05:16 AM
jackietreehorn
I know they can be made to work because there's a bullnose in my neighborhood with a 87+ tailgate. Visually it looks ok, but it is missing some body lines.
Old Aug 10, 2020 | 05:48 PM
dagwood57107
Well I ditched the idea of a newer style tailgate. It "could" work, but too much hassle for me. The hinges are different sizes (not a big deal) but the spot where I need to drill a hole for the striker bolt is severely angled. I'd have to jerry rig some sort of shim for both front and back and its just too much work. On a plus side, I did find an 83 tailgate which isnt too far away (50 miles) so I'll just nab that one instead.
joemahoo
Jul 29, 2020 11:55 AM
davelj
May 20, 2020 07:45 AM
brandon4
2017 Ford SVT F150 Raptor
Jun 8, 2019 09:34 AM
nassi
1978 - 1996 Big Bronco
Dec 16, 2018 06:45 PM
Supercab
Dec 11, 2013 09:55 AM
