2019 F150 payload help
Old Aug 8, 2020 | 01:22 PM
ford390gashog's Avatar
ford390gashog
Originally Posted by diesel_dan
Somehow it seems ford390gashog knew your truck came with 18s, did it? If it came with 20's there's nothing to change because the frame is the difference. If you need to correct for sag or want to firm up the ride when towing, consider adding Firestone air bags and adjustable Rancho 9000s (you want to be able to drop the dampening when you aren't loaded down).
That's how I understand it...
Scott
On edit: your GVWR should be higher if you had the higher rate springs - and those come with 20's. My truck has the same 7050 GVWR as yours and Can't have the heavy springs...
The dead giveaway the truck doesn't have 20" wheels is the low GAWR, which also tells you there is no spring upgrade. The 157wb trucks with MTTP get 3525 front GAWR and 4050 rear GAWR.
Old Aug 8, 2020 | 04:35 PM
seventyseven250's Avatar
seventyseven250
Originally Posted by ford390gashog
Only 2 frames available, Ford tags the frames 145 LD or 145 HD Mini.
Thanks, that's very clear, as most of your posts on this topic have been. Reps sent.
Wing Nut Bert
19
Aug 6, 2020 08:59 PM
Dennis Drotzmann
All Things Towing
Jul 27, 2020 02:44 PM
David Stadulis
Jan 9, 2020 07:07 PM
ecm2
All Things Towing
Sep 7, 2017 04:32 PM
Cecil_Stringer
Jan 23, 2008 10:33 PM
