Oil disappearing
Old Jul 29, 2020 | 09:34 AM
Loftatsea's Avatar
Loftatsea
Oil disappearing
2000 F450 with a 7.3. The last week this truck has been using oil rapidly. Over the past 2 days I've had to add 5 quarts of oil. I don't see any crazy leaks, the engine valley is dry and the coolant is clean. Truck runs ok with no smoke. Driver said it was shaking a little bit. Any thoughts on where it is going?
Old Jul 29, 2020 | 09:57 AM
Brian Hanks's Avatar
Brian Hanks
Simple stuff first.
how is your air filter? If dirty can create a vacuum sucking oil out of engine..
checked your fuel filter recently? If black likely have injector o rings that need attention.
Old Jul 29, 2020 | 10:10 AM
Loftatsea's Avatar
Loftatsea
Just checked the fuel filter. Fuel and filter are black. From my brief research looks like it is o-rings on the injectors.
Old Jul 29, 2020 | 10:13 AM
Loftatsea's Avatar
Loftatsea
Still don't understand why it wasn't smoking though.
Old Jul 29, 2020 | 11:26 AM
jstihl's Avatar
jstihl
When mine started using alot of oil it ended up being the injector o rings . There is a injector O-rings test you can do by applying 100 psi air pressure to the heads where the hpop lines hook up to the heads. If it leaks down quickly the oring(s) are at fault. Another guy on here recently disconnected the hpop lines from hpop, filled the lines with oil and see if the oil goes down the lines over a period if time. I have not tried this method but sounds pretty simple
Old Jul 29, 2020 | 12:25 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Have a look over this thread to see if it is something you can accomplish.
https://www.ford-trucks.com/forums/1...diy-style.html
This link may help you. The author has not returned to provide additional information.
https://www.ford-trucks.com/forums/1...l#post19389441
The 7.3L PSD Tech Folder can be a great resource for you as well.
https://www.ford-trucks.com/forums/1...-7-3l-psd.html
Old Jul 29, 2020 | 12:57 PM
Walleye Hunter's Avatar
Walleye Hunter
That's a lot of oil and they don't smoke because they burn oil. They burn oil so well that they can run on it and they could even runaway on it if they get too much of it, which they could do if it's a turbo seal leak. I don't know if they can, or cannot run away on an O-ring leak.
Old Jul 29, 2020 | 01:10 PM
ford390gashog's Avatar
ford390gashog
Its not going to smoke, there is enough people that run waste oil with no smoke.
Old Jul 29, 2020 | 04:46 PM
RA101725's Avatar
RA101725
Banned
oil in the fuel will add a little haze to the exhaust compared to straight #2 but probably nothing you'd notice during daylight hours. Maybe at night you'd notice it under certain lighting conditions. depends how high the concentration is also.
I thought it was debunked that bad injector o-rings could cause black fuel and filter in the fuel bowl with a stock dead-headed fuel system. It might just be a dirty filter? I'd drain the fuel bowl, put a new filter in and check it over the next couple of days to see if it is obviously getting black quickly.
As said already check the air filter too. If it has the stock crankcase ventilation setup it could be sucking oil out of there if the filter is creating too much of a vacuum restriction under boost.
Old Jul 29, 2020 | 04:51 PM
Sous's Avatar
Sous
FTE Emeritus
@SkySkiJason was talking about this recently. I cannot remember the details, but he said that the fuel filter turning black was in no way in relation to the injector o-rings leaking. Or something along those lines.
Old Jul 29, 2020 | 05:54 PM
Walleye Hunter
The gist of it is that once the fuel is at the heads the chances of it going back to the fuel tank are non existent. It's not like excess fuel goes out the other end of the head and back to the fuel tank as it can in some engines. Therefore, oil from the injectors cannot end up in the fuel tank. I am not an engineer (IANAE) but the logic sounds logical.
Old Jul 29, 2020 | 05:55 PM
Brian Hanks
that’s good to know. Must have missed that.
Old Jul 29, 2020 | 06:51 PM
Loftatsea's Avatar
Loftatsea
But it's not only my fuel filter that is black but the fuel itself in the bowl. That's got to be the fuel mixing in with the diesel somehow. no?
Old Jul 29, 2020 | 06:55 PM
AllaboutMPG's Avatar
AllaboutMPG
Do you have a FRX or other fuel return system or is it completely stock
Old Jul 29, 2020 | 06:57 PM
z31freakify's Avatar
z31freakify
It's posible as I've seen a few dead headed system having oil in the fuel, don't know how it's possible but it is.
