Steering shaft
Old Jul 26, 2020 | 09:37 PM
Heavy hual guy's Avatar
Heavy hual guy
Steering shaft
I'm looking for a new steering shaft and dont know where to find on, I've been looking but I'm not the best, so if someone could point me where to get one it would be great, also what's the difference between reduce vibration and not, and do I need to spend the extra money to get one with reduce vibration
Old Jul 27, 2020 | 01:43 PM
sandymane's Avatar
sandymane
https://www.google.com/search?q=stee...w=1363&bih=643
Old Jul 27, 2020 | 03:03 PM
ave13co's Avatar
ave13co
Steering shaft found. Look at eBay motors, suspension and steering, other. Don't know the year of your truck but there are several listed at eBay
Old Jul 27, 2020 | 04:00 PM
Heavy hual guy
The truck is an 88, and do I need one with the reduced vibration or what's the deal with that
Old Jul 27, 2020 | 04:36 PM
ave13co's Avatar
ave13co
Just went thru that on my 88 last year. First you need to adjust the play out of your steering box..if there is any. I would jackstand the front end and check all steering components for play and looseness. Replace parts and adjust as needed. The once all is tight and steering box is adjusted, if you still have play. Your steering shaft has a flat spot and the rest is round.
I was to this point and still had a minute amount of play. I adjusted it out by inserting a .035 feeler guage between the flat spot and it's housing, tight fit, then I put a simple hose clamp around the shaft and feeler guage to hold it in place. Steers like a race car now. Being a short box helps in the hills too.
While you have it up in the air, might as well check the ball joints too.
Old Jul 29, 2020 | 11:51 AM
hdfe's Avatar
hdfe
Borgeson makes replacement shafts. Did one on my '89 F250 and '90 Bronc, quick and easy and no more play. Before you try to adjust the box, have someone turn the wheel while you watch the shaft. You can see if it's play in the shaft or in the box, or both. More than likely you've lost the plastic sleeve that's in the double D shaped tube, that's probably causing the slop. Follow the instructions carefully.
Old Jul 29, 2020 | 04:56 PM
Heavy hual guy
My dad put in a new steering gear box right before I started driving it, so that is good, and its tight, I know I need new tie rods haven't seen about the ball joints yet, but I can tell it's in the shaft because when the trucks off and you move the wheel you can only move it so far being on the ground and truck off, so the little bit if steering you have only goes down to the box and nothing past that because its not on to work the pump, or so that's what I'm thinking, but I already took the shaft off the gear box and slid the inner piece out to feel that plastic of whatever bushing and that's what it was, but I was telling all of this to my dads friend who made one call and is now supposedly having a guy machine that little bushing part out of billet aluminum, so well see how that goes, but for now I just put some feeler stock in there and called it good for now
Barrakuda
Mar 17, 2017 09:09 AM
stungstang
Mar 28, 2006 08:54 PM
JonnyB69
Aug 5, 2004 10:54 PM
longview1
Apr 21, 2003 02:39 PM
