Water In Differential
Old Jul 25, 2020 | 06:21 PM
Defector's Avatar
Defector
Used my company F150 to launch my boat and now my differential is full of water. Is there a poorly designed vent tube? 2018 Lariat I had the fluid changed already.
Old Jul 25, 2020 | 06:25 PM
ford390gashog's Avatar
ford390gashog
The vent tube is all the way up to the bottom of the bed. How deep did you go?
Old Jul 25, 2020 | 06:30 PM
Defector's Avatar
Defector
Rear tires almost but not fully submerged
Old Jul 25, 2020 | 07:24 PM
fordman19762003's Avatar
fordman19762003
Was there any evidence of leaks before that would allow a spot for moisture to get in?
Old Jul 25, 2020 | 07:39 PM
Defector's Avatar
Defector
No leaks. I was under the truck the day before and looked for leaks while i was messing around with the spare tire. Maybe i bumped the vent line.
Old Jul 25, 2020 | 07:47 PM
ford390gashog
Definitely going to get some water at that depth. Way further than Ford designed. Anything past center of hub and you risk water on any axle. Why did you have to go so far in?
Old Jul 25, 2020 | 07:56 PM
Defector's Avatar
Defector
Its not a very well built or engineered launch. It is what it is. Some guys have to go darn near up to the top of their wheel well. I usually launch it with the superduty and have no depth issues.
Old Jul 27, 2020 | 08:45 AM
Para_Bellum's Avatar
Para_Bellum
That will definitely cause water intrusion in the diff. If you haven't already, crack it open, clean it, and replace the fluid ASAP.
Old Jul 27, 2020 | 09:58 AM
storage_man's Avatar
storage_man
The OP needs a steeper launch ramp.
Old Jul 27, 2020 | 04:00 PM
Para_Bellum
Defector - another thing to consider would be putting a new piece of longer tubing on your diff to relocate the breather higher up - then you don't have to worry about steep boat ramps. Should be super simple to swap with basic rubber tubing from a parts store.
Old Jul 28, 2020 | 10:42 PM
JKBrad's Avatar
JKBrad
Many people run the tubing up behind the tail light.
Old Jul 30, 2020 | 09:05 PM
grm61's Avatar
grm61
On my Jeeps I used to run front and rear vents up to the master cyl and tie off to the brake lines.
Old Sep 1, 2023 | 09:15 AM
mr2020's Avatar
mr2020
1st Gear
Water in Differential 2020 F150. Unknown Ingress Path
My 2020 F150 with 59,300 miles is having rear end bearings replaced because of water intrusion. Dealership and Ford Customer Care says warranty will not cover because of water intrusion. I have never had this vehicle in water depth, only highway and county road driving. There has never been any repair on the rear end/axles. Dealer and Ford Customer Care cannot identify water intrusion path.
When the vehicle was delivered to the Dealer shop for repair, the Service Advisor told me the vehicle would be diagnosed and I would be contacted. No contact was made. When I arrived at Dealer, the rearend was stripped down and repair ongoing. At that time the Service Advisor said warranty would not cover repair because of water intrusion. I called 800 Customer Service and advised warranty would not cover. I have yet to receive Vehicle Concerbn Diagnosis Report.
Are there any accounts of these vehicles coming from the factory with contaminated lube in the differential.
Old Sep 1, 2023 | 12:04 PM
JKBrad's Avatar
JKBrad
None that I have seen posted here. And if was contaminated from the factory, you would have had problems way before the miles you have now. If there is no fluid leaking either from the axle seals, pinion seal or diff cover, then it got contaminated through the vent. The most common way this happens is when someone backs a boat trailer too far down the ramp, driving on a flooded street, or off road stream crossings/mud holes.
Old Sep 1, 2023 | 07:53 PM
diesel_dan's Avatar
diesel_dan
We are starting to see the AI crap here - keep that in mind going forward: new ID equals question... It just wants to get "smarter" And now I'm flagged...
jackstraw
Jul 17, 2015 09:07 AM
Thumper4995
27
Jun 16, 2006 01:52 PM
SkylinePCG
1997 - 2003 F150
Feb 4, 2006 03:01 PM
tealboy1
1997 - 2003 F150
Dec 14, 2005 12:50 AM
xgmist
Mar 2, 2004 05:02 PM
