Clutch rod bushing
Old Jul 25, 2020 | 05:53 PM
unibody62's Avatar
unibody62
Clutch rod bushing
I need to replace my clutch rod bushing and wondered if there is a better option. Currently it has a nylon bushing, I think it's about a 3/8" rod. Not sure if the nylon bushing is original for the year (1962) or not. I think some of the Fords of this era used a brass bushing instead. The nylon are easy enough to come by, if I want to pay crazy shipping charges.
Old Jul 25, 2020 | 07:17 PM
62SY4's Avatar
62SY4
I've used GM door hinge pin bushings because I have a box of them.... You can get plain bronze or oilite. Note the ID is 11/32" so it needs reamed, but usually the rod is worn and needs weld repair anyhow, so I ream to fit.
Old Jul 25, 2020 | 08:11 PM
unibody62's Avatar
unibody62
Thanks for the suggestion. I don’t have those, but maybe they would be easy enough to source locally. Probably would need to enlarge the hole in the clutch pedal also.
Old Jul 25, 2020 | 10:31 PM
62SY4's Avatar
62SY4
I can't promise that you don't have to open the linkage holes but, I don't recall doing that to either my '64 or '67 on the pedal or the z bar.
Old Jul 25, 2020 | 11:14 PM
Christmas's Avatar
Christmas
These are what I used.
https://www.ebay.com/itm/Early-Bronc...ox!95006!US!-1
Old Jul 26, 2020 | 03:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The nylon bushing is original for the year (1962). I think some of the Fords of this era used a brass bushing instead. Not! The nylon are easy enough to come by, if I want to pay crazy shipping charges.​
C0AZ-7526-B .. Clutch Release Rod Split Nylon Bushing - 3/8" I.D. / Reproduced
1961/77 F100/800 // 1978 F100/800 before serial number BA0,001 // 1966/77 Bronco // 1978 Bronco before serial number BA0,001 // Misc: 1960/80 Ford/Merc Passenger Cars.
GREEN SALES CO. in Cincinnati OH has 13 = 800-543-4959.
CARPENTER NOS PARTS in Concord NC has 1,548 = 800-476-9653.
Old Jul 26, 2020 | 10:35 AM
Radams1976's Avatar
Radams1976
Clutch Rod bushing
I made this out of a couple of ball joints (heims joints) and some 3/8 drill stock to replace the clutch pedal rod in my 78 F150. I had the same issue with it. The bushings were worn out and chewed up the clutch pedal rod. I replaced the bushings and repaired the rod but eventually the rod broke.
Old Jul 26, 2020 | 12:11 PM
unibody62's Avatar
unibody62
The rod broke on my 65 that I had 25 years ago. Got it welded and it did hold up ok for the years I had it. I saw those when I was searching and I’ll look into that also. I’m not sure I want to go to that much trouble for something that won’t be driven much. Even down the road, I may convert the clutch pedal to hydraulic assisted. My left knee is starting to bother me, so it may be too painful to use the stock set up as I get older. Thanks for the ideas!
dogdays
Oct 24, 2018 07:05 PM
lemonshindig
May 4, 2010 08:41 AM
jeffreysw
Jan 26, 2010 06:15 PM
GregTruck
Nov 7, 2004 05:15 PM
tony_1
Jan 27, 2000 01:44 AM
