Jeff's Bronco Graveyard?
Old Oct 23, 2018 | 04:06 PM
dogdays's Avatar
dogdays
Anyone had this problem? The clutch linkage rod broke and I ordered a new one from Jeffs Bronco Graveyard. The new rod is very nicely built except the ends of the rod that ride in the plastic bushings in the lever arms are too large in diameter. The old rod had 3/8" diameter pin ends, the new rod is more like 7/`16". The outside diameter of the bushing is something like 0.482. So the new rod doesn't fit in the original bushing and the new bushing doesn't fit in the original hole. The new rod fits in the original hole without a bushing and that's how it's set up now.
So I spent about $10 on new bushings that I cannot use unless I drill out the holes in the arms to accept the new bushings! Is this typical?
I have emailed JBG but not enough time has passed to get an answer.
R.
Old Oct 23, 2018 | 11:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So I spent about $10 on new bushings that I cannot use unless I drill out the holes in the arms to accept the new bushings! Is this typical?*
What year/series truck, what engine? If this is a 1977 thru 1979 F100/350, I need the last 6 digits of the VIN
*Depending on the year and the last 6 digits of the VIN, there are two different nylon bushings, two different rods.
Old Oct 24, 2018 | 03:36 PM
dogdays's Avatar
dogdays
Jeff is a Standup Guy!
I received an almost instant message from Jeff to refund my $10.00. What a standup guy. I had suggested store credit as I see some things in his catalog that I need. But the $$ has already been returned to my bank account.
The truck VIN is F15HRX81328 and it was built in late 1976. The bushings that came with the clutch rod have a Ford part number that starts with F8.
R.
Old Oct 24, 2018 | 07:05 PM
highoctane74's Avatar
highoctane74
Now that's good service!
Snorri_B
Nov 11, 2012 06:25 PM
lemonshindig
May 4, 2010 08:41 AM
jortega3333
Jan 28, 2008 06:01 PM
F150Lariat79
Apr 28, 2005 04:25 PM
GregTruck
Nov 7, 2004 05:15 PM
