Brake Controller Fault Message
Old Jul 25, 2020 | 12:29 AM
Jr King's Avatar
Jr King
Has anyone had an issue with Trailer Brake Controller giving a Fault message? My 2019 F350 is just a week old and giving this message as I heading out with my RV on a vacation. Replaced 7 prong plug on my RV and checked full wiring harness on trailer. I am fully connected and everything from lights, brake lights, signal worked but the Electric Break has a Fault message and No Electric Brakes. I took my truck to a friends house and got the same message when I hooked up to his RV. NO VACATION FOR ME, WEEK ONE WITH MY NEW FORD. Worked great on my Tundra for the last there years.... UGH!
Old Jul 25, 2020 | 06:43 AM
seville009's Avatar
seville009
Check fuses maybe?
Old Jul 25, 2020 | 09:01 AM
HRTKD's Avatar
HRTKD
Check the connections on the backside of the 7 pin connector. I think one forum member reported a bent pin causing problems.
Old Jul 25, 2020 | 09:01 PM
Justvisiting1's Avatar
Justvisiting1
what he said, plus if you haven't heatd, this is a good read.
I Dielectric greased every connector under my truck...
https://www.ford-trucks.com/forums/1...ns-solved.html
Old Jul 25, 2020 | 09:07 PM
HRTKD's Avatar
HRTKD
I did the same. If it was a connector, I greased it. Front bumper to rear bumper. Now that the tailgate field service action (was it a recall?) has been completed I need to get under there and check to see if the new connectors need to be greased.
Old Jul 25, 2020 | 09:56 PM
Justvisiting1
Dont know about the tailgate, mine only locks and unlocks, no auto open.
never hurts to check it though. Had less then 1000 miles when I did mine. Hoping to prevent future troubles
Old Jul 26, 2020 | 06:13 AM
senix's Avatar
senix
Usually is the wiring connections to the 7 pin, truck side.
Old Jul 26, 2020 | 09:01 AM
mtnguy's Avatar
mtnguy
Mine does that occasionally. I probably need to tighten the prongs some, and use dielectric grease on the connectors.
carolinaborn82
2009 - 2014 F150
May 25, 2017 05:26 PM
tshrager
Jan 10, 2012 05:55 PM
1duallyman
Electrical Systems/Wiring
Jun 9, 2011 05:49 AM
AC-MAN
May 8, 2010 10:06 AM
oppy
All Things Towing
16
May 18, 2004 10:49 AM
