Sponsored by: Real Truck
Possible limp mode?
Old Aug 25, 2020 | 06:29 AM
Djosbun's Avatar
Djosbun
Did you check the harness connectors thoroughly, especially where the wires enter?
-- Dave
Old Aug 25, 2020 | 02:53 PM
gabriell12123's Avatar
gabriell12123
-- Dave
yes the harness checks out good
Old Aug 25, 2020 | 05:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Have you checked the harness electrically or visually? If you haven't used a meter to detect opens or shorts you haven't checked the harness. Looking at the harness only will find the most obvious problem.
Did you look inside the insulation where there is soot on the harness? How does the copper look inside the wire? An electrical test could answer this question.
Old Aug 27, 2020 | 04:50 PM
gabriell12123
okay so I just got done going through the harness with a volt meter measuring for resistance and I had a couple wires that measured between .2-.7 ohms is that a bad thing? If not where do I go from here?
Old Aug 27, 2020 | 05:42 PM
Mark Kovalsky
No, those readings are not bad. How many ohms did you read when you checked each wire to ground and separately to power? Those two should be open circuits, if you get a reading it indicates a short circuit.
Old Aug 27, 2020 | 06:06 PM
gabriell12123
how do I go about doing this? I still have the harness out of the truck right now am I gonna have to reinstall it first? I apologize for the lack of knowledge... maybe there’s a good video that’ll dumb it down for me
Old Aug 27, 2020 | 08:53 PM
Mark Kovalsky
There probably is a video. I've never looked for one.
Yes, you have to install the harness. Don't plug in the PCM or the transmission. Check the wires for continuity to power and to ground.
Old Aug 29, 2020 | 03:29 PM
gabriell12123
Okay I did some more digging today and found a short on circuit 22 (maxi) junction box fuse/relay panel battery feed, so I move to interior fuse box under the dash and I get to fuse 15 (GEM module/BPP switch) and there was a short on that circuit. I spend some time taking out the fuse box to get to the gem module and when I get the connectors off I can tell there where a little dirty and wet I get the gem separated from the fuse box and open it up to a big ol carpenter ant that I’m guessing got fried on the leads I’m hoping this helps I’m sure this was causing a problem somewhere but hopefully it helps the real problem, waiting for it to dry up outside a little so I can seal the module tight to keep water and bugs out
Old Sep 4, 2020 | 09:19 AM
gabriell12123
Bump still need help
gabriell12123
Jul 18, 2020 01:28 PM
Kellip25
Modular V8 (4.6L, 5.4L)
Dec 31, 2018 05:03 PM
K10A
Jan 19, 2014 08:41 AM
mustangmike
Jul 31, 2006 11:09 AM
Jimmyk
Jul 29, 2004 09:02 AM
