Leaking Battery
Old Jul 24, 2020 | 09:07 PM
minke's Avatar
minke
Originally Posted by ford390gashog
... I still don't understand why Ford went to AGM on all the other cheaper vehicles but can't give AGM as standard in the SuperDuty.
Without actual inside knowledge (or facts!) I presume that AGMs went to vehicles with (I don't know the correct name) auto start-stop. By this I mean those engines that turn off when you stop and restart when you remove your foot from the brake.
When my F-250 was destroyed by hail my insurance company got me a BMW series 7 for a few weeks and a Jeep Compass for a few weeks. Start/stop on the former was worked well while on he latter it was poor.
Old Jul 24, 2020 | 09:52 PM
Lamoon78's Avatar
Lamoon78
Originally Posted by Mikelikesit
OK thanks. Im thinking Ill dump some water and baking soda over it and go and take it to them when I get back. What you say sounds plausible. Its pushing right out a fine seam that runs around the top of the battery.
Might as well just take the battery and buy your own the ones Ford uses are junk. I have 2 F350 a 6.2 and 6.7 both 19’s and they leak. The 6.7 has been replaced and leaking again I already replaced the one on the 6.2 the 6.7 is next.
Old Jul 25, 2020 | 12:50 PM
mtnguy's Avatar
mtnguy
I noticed my driver’s side positive cable clamp starting to corrode on my 2017 PS about 15,000 miles. I cleaned the clamp and installed a “disc” to prevent further corrosion. On a trip out west, I again noticed corrosion, and had a Ford dealer in Wyoming clean the terminal and clamp again during a routine oil change at 20,000 miles. Once home and during my next oil change at my local dealer I explained the reoccurring problem. They replaced that battery, and also installed a new battery cable since the old clamp was questionable at that point. All has been good since.
Old Jul 25, 2020 | 06:06 PM
Defector's Avatar
Defector
Thanks Mike, Im a newbie and havent heard about this yet. I better check mine
Avanti
Escape & Escape Hybrid
Dec 21, 2019 12:28 PM
2018f250stx
Sep 10, 2019 11:35 AM
HouseMouse
Oct 16, 2017 11:16 AM
john fin
Nov 24, 2011 06:11 PM
F350Ford57
Electrical Systems/Wiring
Dec 26, 2006 10:04 AM
