Computer Chips & Tuners
quarter horse
Old Jul 24, 2020 | 10:59 AM
Trenton Tbone Giordano's Avatar
quarter horse
will this programmer work with my 1987 F250 port fuel injected 300, i just finally got the final parts to turbo the truck and wanted to know if the quarter horse will tune the f250 since it works on my 2002 ranger
Old Jul 26, 2020 | 07:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
nope. completely different engine programming.
Old Jul 26, 2020 | 09:10 AM
Conanski's Avatar
Conanski
So you have a J3 port Quarterhorse module?
What software are you using with it?
The hardware will work with a wide range of PCMs and 3 different software packages so technically it could work with your '87 PCM but you need the correct strategy file for it and that is where you may discover a roadblock, if no strategy file is available then you can't tune that PCM.
Old Jul 26, 2020 | 09:14 AM
tjc transport
i ain't rite
how would you connect it to the 87? it does not have an OBD port.
Old Jul 26, 2020 | 10:34 AM
I use tuner pro RT and have had it work great I the ranger, the 87 f250hd is the 4.9 with t18 efi and i wanted to wait and ask if this one had the j3, I have the bin adx and xdf for the engine just would like to know if it has the port, I really just want to get rid of all the emissions garbage and put 3-4 pounds of boost into it
Old Jul 26, 2020 | 10:41 AM
The quarter horse uses the J3 port that was very popular in many ford cars such as the foxbody mustangs in 86-92, my 2002 ranger with the 2.3 duratec dual overhead cam Mazda engine and m5odr1 was boosted and made 280 ish HP, but an engine having 253K was not a good candidate as the rings in cyl 3 went out and lost compression so I'm gonna get the sleeve removed fresh sleeves and such and all forged but all of the tuning I have done through the J3 on the pcm using a 2005 ranger bin file witch had the mech thermo and no anti theft
Old Jul 26, 2020 | 11:04 AM
Conanski's Avatar
Conanski
All OBD1 Ford PCMs have the J3 port, it would be interesting to many I'm sure if you could make this work.
Old Jul 26, 2020 | 11:06 AM
All OBD1 Ford PCMs have the J3 port.
Sweet, and just to make sure the pcm is by my throttle petal right
Old Jul 26, 2020 | 12:20 PM
tjc transport
i ain't rite
no. pcm is behind the parking brake in the driver side kick panel.
you have to unbolt it from the engine bay, then slide it out. from inside the cab. if i remember correctly, you have to remove the parking brake assembly to remove the cm too.
Old Jul 26, 2020 | 12:23 PM
no. pcm is behind the parking brake in the driver side kick panel.you have to unbolt it from the engine bay, then slide it out. from inside the cab. if i remember correctly, you have to remove the parking brake assembly to remove the cm too.
Do they make a harness extender so that I can move the pcm up to the radio position since I don't use the radio I use my Bluetooth
Old Jul 26, 2020 | 12:29 PM
tjc transport
i ain't rite
no. the pcm plugs into the engine bay wiring harness.
Old Jul 26, 2020 | 12:39 PM
I was asking if there were harness extensions like how home depot sells 10ft wall outlet extension, do they make a harness connection extender i can buy online
Old Jul 26, 2020 | 01:30 PM
tjc transport
i ain't rite
i highly doubt it, it would have to have around 50 or so wires in it.
Old Jul 26, 2020 | 01:40 PM
Thank you also is there any specific version if the ,5.0 that I can't use the 19lb injectors, other than the tbi model
Old Jul 26, 2020 | 02:03 PM
tjc transport
i ain't rite
no idea. i know absolutely nothing about the 302 other than it is way too small for anything i own.
Apr 2, 2020 06:19 PM
Sabes76
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 18, 2013 08:00 PM
blackinkforge
Engine Swaps
Mar 25, 2008 06:21 AM
Nighteyez
N. California Chapter
37
Mar 28, 2007 11:57 PM
Difles
23
Oct 21, 2004 06:25 PM
