HeIlo,
I have a few questions about the fuel return.
I am currently cunning low injection pressure, I put a new pump on and installed a new fass fuel system. I pulled all the injector return lines off and checked to see if I had a bad injector.
All of the injectors looked fine, but i did notice the return line was kicking out alot of diesel... Is that normal when the pump is not making full pressure?
What should i look at?
Thanks in advanced
