What’s your temp?
Old Jul 20, 2020 | 07:52 PM
arno's Avatar
arno
What’s your temp?
17 3.5 ecoboost, 40k, truck runs around 227 average on the highway. In town 220 or so. High so far 234, on the highway. Curious what others are seeing. Ford says it’s fine to be that temp. Had a 16 that ran about 208-210, same with another 18.
Old Jul 21, 2020 | 07:23 AM
irocdupi's Avatar
irocdupi
I usually run around 210 on the highway. If im going up hill with the turbos spooled up i Will run around 219 220 until I back off the turbos.
Old Jul 21, 2020 | 08:45 AM
brian6674's Avatar
brian6674
2020 2.7, 2dr short bed 4X4. 198 <-> 204degs.
Old Jul 21, 2020 | 09:08 AM
scott91370's Avatar
scott91370
2015 3.5 here and since I changed to the 180* thermostat the only time I see over 200* is just as the thermostat opens, unless I'm running it hard or towing. But seeing 225+ hasn't happened since the new thermostat .
I think these engines are designed to run hotter for emissions purposes - just my thinking, nothing to back it up. I didn't like it so cooler thermostat was my choice.
Old Jul 21, 2020 | 10:20 AM
arno's Avatar
arno
In changing the thermostat did the computer adjust ? Or did it need to be reprogrammed?
Old Jul 21, 2020 | 10:26 AM
scott91370's Avatar
scott91370
I made no other changes than the thermostat. I guess if the computer needed to adjust it did everything on its own,
Old Jul 21, 2020 | 10:28 AM
OVRLNDFX4's Avatar
OVRLNDFX4
Im assuming this is for the trans temp correct?
Old Jul 21, 2020 | 10:36 AM
scott91370's Avatar
scott91370
Nope, engine coolant. Hence the thermostat.
Old Jul 21, 2020 | 11:01 AM
arno's Avatar
arno
What is the factory thermostat temp in a 17?
Old Jul 21, 2020 | 11:13 AM
scott91370's Avatar
scott91370
Pretty sure they all came with 190.
Old Jul 21, 2020 | 11:31 AM
arno's Avatar
arno
So my thermostat is a 190 and the truck runs 227 on the highway, and the fans run on high, a lot, seems odd that this is the proper cooling strategy lol.
Old Jul 21, 2020 | 01:29 PM
OVRLNDFX4's Avatar
OVRLNDFX4
oh ok. i dont see any type of digital temp readout for the engine in my 19 xlt 3.5. only a trans temp digital readout
Old Jul 21, 2020 | 03:22 PM
arno's Avatar
arno
if the truck gets above a certain temp it will start showing numbers right above the temp gauge.
Old Jul 21, 2020 | 04:40 PM
OVRLNDFX4's Avatar
OVRLNDFX4
Oh wow, didnt know that! Hope i dont see that display!
Old Jul 21, 2020 | 04:48 PM
ford390gashog's Avatar
ford390gashog
This is for the Lariat and above, the XLT and below doesn't have that ability.
