1997 f250 7.3 no start help!
Hey all, im having a bit of trouble getting my 7.3 running. Cranks but doesn’t start and no smoke which mean no fuel right? Have a tach signal reads about 150-200 while cranking and i do get fuel from the shrader valve while cranking. Oh and a little back story it had been sitting for about 2+years but started right up when we got it about 6 months ago and never had any issues up until 2 months ago it started taking a little longer to start( took about a minute of cranking) then it wouldn't start at all. Things we have done are new icp sensor, new ipr valve, when it wouldnt start we decided to replace glow plugs and injector o-rings just for fun, the hpop reservoir is about 1 inch from the top. What should i check for next? Any help is appreciated thanks in advance.
Hey thanks for replying, how accurate would that be because i did it and got about 10 psi with a pencil gauge is it worth trying to get a hold of a good fuel pressure tester to double check or should i just buy the fuel pump?
harold1814
07-18-2016 10:08 PM
dumptruck denny
60
02-14-2015 06:53 AM
