Intercooler Water Mister
Old Jun 24, 2021 | 12:17 PM
  #31
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Y2KW57
Risk.
Or lack thereof.
There isn't much risk in misting the outside of the intercooler.
There are real risks associated with injecting water/meth into the engine.
That sounds like a challenge.
Old Jun 24, 2021 | 01:46 PM
  #32
ESwift's Avatar
ESwift
CNCFAB
I have water injection ready to install tomorrow or saturday
Old Jun 24, 2021 | 02:08 PM
  #33
Hvyhaulr's Avatar
Hvyhaulr
Originally Posted by brokestroke
So far I have used it towing my 24ft stock trailer. Without misting MAT got easily up to 120°. Spraying the IC down lowered temps by around 15-20° to around 100-105°.
was that enough to feel a power gain or EGT reduction?
Old Jun 24, 2021 | 04:17 PM
  #34
FinnishStroker's Avatar
FinnishStroker
I have had Snow Performance MPG-MAX kit ready to install for a looong time.
Old Jun 24, 2021 | 05:23 PM
  #35
brokestroke's Avatar
brokestroke
Well the common saying is a 10° drop = 1% hp gain.
1% of 320hp is 3.2hp, 20 degree drop equals a 6.4hp gain. The temp drop is more noticeable coming to, then taking off from a stop and the when the mist compensates for less airflow. In those situations the temp can MAT can drop 30°. In those cases I guess you could say its good for a 9.8hp/20tq gain. . This is using water that is around 45°.
Old Jun 24, 2021 | 05:59 PM
  #36
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Another benefit of running cold water in the 33 - 45° range is that you have a secondary or tertiary location to store frosty adult beverages made with barley and hops.
Seriously though, there is a photo that @Tugly took years ago with an endoscope stuck down into the intercooler. The oil accumulation seemed insignificant as Y2KW57 eluded to and specifically stated backed by measurements and scientific methods.
Old Jun 24, 2021 | 08:52 PM
  #37
Hvyhaulr's Avatar
Hvyhaulr
nothing noticeable from an EGT standpoint?
Old Mar 9, 2022 | 07:51 PM
  #38
brokestroke
Back at this and finally wired it "proper" for real world towing use. The pump is still hooked up to the dimmer switch like the pictures before. Now I have split the ground and use a 2 position toggle (two on positions) with a 1/4" activation LED light.
The first ground goes to the body and is for standard misting use. Flip the toggle to this position and the pump turns on at whatever rate the dimmer is set to (0%-100%). The 1/4" LED kicks on as well.
The 2nd ground is more complicated. Ground starts in the engine bay. It leads to a grounding temperature probe in the intake Y. Ground closes at 140°f and opens at 125°f. From there the ground wire goes to a 10psi switch mounted in the intercooler pipe. It then leads to the toggle switch.
Switch the toggle to the 2nd position and now the system is "armed" for towing. In order for it to turn the mister on two things need to happen simultaneously. The MAT must reach 140°f and MAP reaches 10psi. When those two things occur, the LED lights up, pump turns on (at desired %) and misters run until MAT falls to 125°f. If boost falls below 10psi it shuts off. This is so it doesn't run at stoplights, traffic, etc.
Going to give it a good test. If it works I plan on getting a larger tank with an easy fill.
Old Mar 9, 2022 | 08:12 PM
  #39
Wes444's Avatar
Wes444
Running distilled water or tap?
Old Mar 9, 2022 | 08:18 PM
  #40
brokestroke
Filtered tap. Didnt run it in close to a year, had to blow out two tips since last use.
Old Mar 9, 2022 | 09:25 PM
  #41
Hvyhaulr's Avatar
Hvyhaulr
Did you notice any EGT drop?
Old Mar 10, 2022 | 06:41 AM
  #42
brokestroke
I will let you know shortly, although my truck doesnt have any EGT issues. Will also get some pictures of how it is set up now.
Old Aug 9, 2022 | 10:31 PM
  #43
Hvyhaulr's Avatar
Hvyhaulr
Anymore updates to report?
Old Aug 18, 2022 | 07:49 PM
  #44
brokestroke
Got the system completely plumbed, wired and functioning. A few things to note, with the S363 the 10psi pressure switch is too light, need to change to a 20psi +/-. It hits 10psi to easy, so once temps hit 140* towing it wants to stay on all the time. Simple fix, just switch out the 10psi switch with a 20psi, the current 10psi is an oil pressure sender for a Generac generator. Think I will keep the 140 degree intake probe though, seems to be a good zone to work with, just adjust the psi switch.
Also thinking about changing the entire pump/tank/nozzle assembly. The washer pump/res worked and cost $0 but doesn't hold enough water to be practical. My thought is to use a 15 gallon FimCo sprayer tank and pump with 1 or 2 larger nozzles that are used for spraying fertilizer/chemicals, more resilient with filters in them. The 15 gallon FimCo sprayer with pump runs $120. Grab a couple nozzles and some hose and leave TSC for under $150. The FimCo will also spray more water in a shorter duration so it theory it will run less and be more efficient.
The other issue is the truck. The turbo/tuning/gearing is dialed in to the point where this is pointless, but it is fun and I enjoy messing with it. With a 15 gallon tank and high flow nozzles it will make for better testing and yield more accurate results. My thought is to mount the 15 gallon FimCo on the transfer tank behind my cab, that way I can see the water level out of my rear view mirror.
Old Aug 26, 2022 | 06:30 AM
  #45
FordTruckNoob
Solution:
TheDuke
Aug 25, 2018 09:26 AM
amdriven2liv
Sep 14, 2011 06:17 AM
starmilt
Jan 23, 2010 06:05 PM
rmalottwtes30
Mar 28, 2008 06:09 PM
Charlotte
1983 - 2012 Ranger & B-Series
13
Jan 26, 2004 07:22 PM
