Engine oil cooler
Old Jul 18, 2020 | 07:36 AM
kefrko's Avatar
kefrko
Engine oil cooler
I am starting to see some signs that my oil cooler is leaking oil. I have a 2000 f350 CCLB with about 275K miles. I’m hoping to wait until the weather cools a little to do the work on it but just trying to get a gameplan together. Is it recommended to replace the cooler and the o-rings/gaskets? Or can you just get away with just o-rings/gaskets? And if I do need to replace the cooler, has anyone had good results with an aftermarket part or is everyone using the ford part. I haven’t noticed any oil in my degas bottle nor have I seen any coolant in my oil changes if that has any relevance. Thanks for any insight you can provide
Old Jul 18, 2020 | 07:55 AM
jstihl's Avatar
jstihl
you should be fine to reuse your oil cooler and just replace gaskets/orings as long as your cooler isn't in really bad shape. Its best to make sure to clean surfaces where o rings/gaskets are really good to ensure proper sealing. Mine is leaking on my f350 and will be doing this soon as well. I did the cooler on my f450 and it was a pita, although alot of folks on here say its not to bad.... make sure you get the oem orings, i got some from a Ford dealer on ebay
Old Jul 18, 2020 | 05:32 PM
JSPEX's Avatar
JSPEX
I replaced my cooler and orings a year ago with dorman. Within 4 months it was leaking again. Finally 2 weeks ago replaced the orings with motorcraft from Riffraff. No leaks so far and hopefully stays that way.
Old Jul 18, 2020 | 05:34 PM
F0rdc0wb0y's Avatar
F0rdc0wb0y
preparing to do this myself along with several other mods.
Old Jul 18, 2020 | 05:38 PM
JSPEX's Avatar
JSPEX
Oh, and the first time around I watched YouTube videos of guys leaving the front mount attached and just removing the rear mount. Didn't go so well for me, lost a front orings up where I couldn't see while reinstalling. That led to an extensive (expensive) period of flushing the oil and cooling systems. After that I removed both ends and assembled the whole thing on the workbench, which worked much better.
2006fordf25060
May 2, 2018 06:40 PM
DavidLM11
Dec 6, 2016 11:14 AM
Blurr4x270
6.4L Power Stroke Diesel
Dec 14, 2015 10:52 PM
jspence105
Aug 24, 2015 03:33 PM
mudfuel06
Aug 8, 2014 12:04 PM
