Sometimes have difficulty filling tank
I sometimes have difficulty filling my tank with diesel. This is a '95 ambulance with the 30gal tank in the middle-rear. Think box truck.
The diesel seems to sometimes settle in the middle of the hose where it doesn't drain quickly into the tank. It's exaperated by diesel that foams and also when the vehicle is leaning towards the pump (I *think* the second issue is more critical).
Any suggestions regarding how to solve this issue? There isn't a massive kink in the hose or anything like that. Maybe I have to replace the hose with something hard & straight, although I'm not sure what unless I custom weld a pipe.
OK, disregard that brain fart. There is clearly a vent (I must have been remembering a different vehicle). The vent and fill pipe are welded together near the inlet and bend slightly downward, annoyingly. I'll see if I can remove the vent hose and at least see if it's clear.
Somewhat relatedly I found out why my vehicle is leaning towards the pump: the suspension shackle is broken. I'll have some fun fixing that first.
Received 3,206 Likes
on
cowboy73
30
02-03-2008 07:25 PM
