1997 f250 4x4 psd ..4x4 wont engage
Truck was sitting for the winter like every year and normally I leave it in 4 by 4 but I forgot and now 4x4 won't engage.. shifts into 4hi and 4lo and the lights everything come on but no four-wheel drive.. I think it's my hubs they are automatic.. I was going to service them this Summer anyhow as it's being a hundred thousand kilometres since the last time
Received 3,203 Likes
on
on
So it was the left front hub that wasn't engaging got all fixed up good to go there but while I have your attention. I have another issue.. I thought my starter went and swapped it out for a new one and still does the same thing and I've replaced the fender relay last March.. can jump the starter from below and will run but I hear what sounds like the starter trying to engage? The voltage stays low and will eventually come up as the noise goes away after a few minutes.. I put a new steering column in last year.. with the same key switch.. going to check the wire from the fender relay to the starter as soon as my buddy gets here with his ohm metre.
Jpellerin
1999 to 2016 Super Duty
01-05-2020 09:04 PM
