Whining Power Steering Pump
Old Jul 23, 2020 | 01:02 PM
95fiveoh's Avatar
95fiveoh
Either would probably be fine, but GM specs power steering fluid for Saginaw pumps. That's what I used.
Old Jul 24, 2020 | 11:59 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Originally Posted by GavinL
Just got my new pump. Desolate motorsports sells a new one with a bracket, lines and new belt. I plan on putting it in this weekend. Did you use ATF or Power Steering Fluid for the Saginaw pump.
Link to Desolate Motorsports kit? I'm guessing just available for the V8?
Any way, I'm using the Valvoline Power Steering Fluid that's supposed to be good for lots of PS applications. I'm using it in both vehicles I'm converted to a Saginaw and it works fine.
Old Jul 25, 2020 | 11:22 AM
GavinL's Avatar
GavinL
Finally, how do you get air out of the pump and lines? Is it the same as the Ford pump, where you just turn the steering wheel?
Old Jul 25, 2020 | 05:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Same. With the front tires in the air I turn the wheels lock to lock with the engine off, topping off the level as needed. After doing that several times, I start the engine and repeat the process until no bubbles appear in the reservoir.
Old Oct 23, 2020 | 05:25 PM
GavinL's Avatar
GavinL
Here is the link.
https://desolatemotorsports.com/shop...ype-pre-order/
Old Oct 24, 2020 | 01:12 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Thanks. As I suspected, just for the V8. And damn, at $549 they're awfully proud of that. I need to spend some more time at the junkyard checking out the vans!
Old Oct 24, 2020 | 01:14 PM
GavinL's Avatar
GavinL
Yea i didnt want to deal with digging through however many vans and junkyards so I bit the bullet. Should be installing this week.
Old Oct 24, 2020 | 03:19 PM
eagle275's Avatar
eagle275
Is this the same for a 96 F-350 w/460? I've been meaning to do this for awhile now but forgot the details.
eldonkey
May 18, 2011 07:27 AM
Cerpindicular
Apr 17, 2011 11:12 PM
dvdgzzrll
Oct 17, 2010 06:47 PM
Mathematicus
Tennessee Chapter
Mar 10, 2010 01:33 PM
LARIAT 85
May 14, 2006 06:18 PM
