2002 f350 PCM looses power for split second
Old Jul 14, 2020 | 05:48 PM
1995steroker's Avatar
1995steroker
I have a 2002 f350 crew cab short bed driving down the road The truck just goes to idle and have no throttle response The glow plug sign the water and fuel sign and the engine sign all come on. If I let off the pedal the truck has throttle response again and a couple seconds later all the lights go out. It happens in all range of speeds, any help would be appreciated.
Old Jul 14, 2020 | 07:37 PM
AllaboutMPG's Avatar
AllaboutMPG
Definitely sounds like loose wire, loose fuse, bad contact, etc.
Some have found that with the age of our truck the contacts for fuse have lost some of the holding power / friction. check for loose fuses by wiggling.
Also check the 42 pin harness on top of the engine where it crosses the driver side valve cover. See if it has chaffed on the valve cover and worn thru.
Does your overdrive light flash when this happens? if so you may need to open the covers on the steering column and check the wire harness on top for chaffing. Let us know what you find.
Old Jul 14, 2020 | 09:58 PM
z31freakify's Avatar
z31freakify
Has it always done this? I ask because I had a similar problem with a side job I did in an 02. That thing would go to idle if you did WOT and would not go over 75 mph, turns out that truck was tuned to do that on purpose by the previous owner, the way I found out was by changing the pcm with a spare I had, weird but I guess the guy had kids that liked speed
Old Jul 14, 2020 | 10:09 PM
1995steroker
I will look at all this stuff tomorrow. Thanks.
Old Jul 14, 2020 | 10:10 PM
1995steroker
Just started about a week ago.
1995steroker
Jul 16, 2020 05:13 AM
1995steroker
Jul 13, 2020 01:58 PM
Dusty Prisk
Aug 22, 2019 05:41 AM
Emyl
Oct 19, 2012 07:39 AM
HTi-Enright
Jan 7, 2008 07:14 AM
