Some basic questions from a newbie.
Old Jul 13, 2020 | 04:52 AM
augustmaine's Avatar
augustmaine
Hi all,
I’m in the early stages of planning a project and have some basic questions.
I’m looking to build a truck off a mid 60’s F frame. I’ll be replacing the engine with a Cummins and upgrading transmission, axels, etc.
Since I’m basically looking for a chassis and cab, how different are the cabs and chassis size across the 150-250-350-500 platforms? I don’t want to limit my search for a nice body if they’re relatively the same.
Thanks in advance.
Old Jul 13, 2020 | 08:39 AM
66v8baby's Avatar
66v8baby
The cab size is the same across F100 to F500 from 61 to 66 with a slight increase in head room beginning in '64. The floor pan changed in '65 for F100 and F250 2wd with the introduction of the twin I beam front axle. The model changed for '67 for F100 to F350 but may have held over for F500.
Old Jul 13, 2020 | 10:06 AM
augustmaine
Awesome. Thanks for the info.
Old Jul 13, 2020 | 07:12 PM
53deere's Avatar
53deere
Frames get heavier as you move up to the F250 and F350. They can be easily swapped but the F350 will have large radius front fenders if that matters for what you're building.
Old Jul 14, 2020 | 11:45 AM
Thunderkiss1965's Avatar
Thunderkiss1965
I have a nice 65 f-100 cab in california...No rust
Old Jul 14, 2020 | 03:55 PM
rdixiemiller's Avatar
rdixiemiller
If you're going to do a Cummins swap, I think I would look for an F-350 or larger truck. Heavier frame, more room to work (no front crossmember under the oil pan.
Also, the larger trucks aren't nearly as popular (Expensive) as the pickups. The only downside is you don't get a pickup bed, unless you build something custom.
I have seen an old F-600 turned into a pickup, using a military M-105 trailer bed. Really common item, cheap, old school ****** style fenders.
People who turn M35A2's (Deuce and a half) into "Bobbers", single axle pickups also use the M105 trailer body for a bed. They provide a neat way to make a cool looking pickup out of a bigger chassis. Really heavy metal.......
Old Jul 15, 2020 | 10:10 AM
lewiscrouse's Avatar
lewiscrouse
Subscribed. I'm interested in swapping a diesel under the hood of my truck as well. Curious to watch and see how you do it.
Old Jul 15, 2020 | 01:07 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Not sure what Cummins the OP is looking at swapping in, but this is a thread showing a 6BT 12V installed in a 1966 F250 4x4. Not a ton of details but a few good shots of the engine compartment.
https://www.ford-trucks.com/forums/1...body-shop.html
belshe92
13
Apr 29, 2016 12:41 AM
Ford_Six
Aug 8, 2014 09:09 PM
FoxBody91
Oct 8, 2011 03:08 PM
sapper524
Feb 23, 2011 10:40 PM
ky509
Mar 29, 2007 10:52 AM
