steering wander
Old Dec 10, 2021 | 08:02 PM
cficare's Avatar
cficare
Originally Posted by Norris McCarty
The wandering may improve with miles but I’ve replaced the stock caster bushings on my last two super duties to absolutely cure the wandering.
Nailed it! Needs more caster. Feels too free going straight with no on-center stability (must confess I have less than 1K miles on my 2022).
Old Dec 10, 2021 | 08:18 PM
rob17's Avatar
rob17
Originally Posted by 4wd6.7L
My '19 has always had a bit of a wandering feeling on the highway. They say the tires need 300mi to break in, in your case I would give it at least that amount of time, then reevaluate the condition. Seems a little odd that removing the stabilizer makes it track straight (according to your dealer).
The wandering feeling I have experienced has remained after thousands of miles, and even though my factory stabilizer was changed out (Bilstein) at around 3k miles, it had no affect on the slight wandering feeling. One of these days I'll get it on an alignment rack, I suspect it could be dialed in better.
Originally Posted by Nogyro
Maybe it's just the Goodyear tires, don't know but I never thought it would have settled down as bad as it was. I was afraid I was going to get pulled over for dd.
I have Goodyear tires on my 2020 F350 with 7k miles and it's still wandering. Drives me nuts, perfect truck otherwise.
Rob
Old Dec 10, 2021 | 08:23 PM
Spokaloo Jim's Avatar
Spokaloo Jim
2021 Wander
I have a 2021 F350 that has wandered terribly since new. The Michelin tires were replaced at 2000 miles with Open Country III's. This has helped some but the truck still requires constant steering input. The alignment was checked and the steering was inspected by the dealership. Reducing tire pressure makes no difference. I have owned F250's and F350 for the past 25 years and none of them drove poorly as this truck does. I am at a loss for what to do next. I don't want to start throwing parts at it hoping I will hit on what is causing the problem. The truck has 4000 miles on it now.
Old Dec 10, 2021 | 08:43 PM
4wd6.7L's Avatar
4wd6.7L
Rob
Mine are the Michelin's but still could be tire related.
Old Dec 10, 2021 | 09:31 PM
KeystoneF350's Avatar
KeystoneF350
If you're unhappy with the current wandering behavior, I'd suggest changing the caster bushings. SPC makes a set specifically for 4x4 Super Duties that is +2.6 degrees caster on the passenger's side, and +2.3 degrees on the driver's side (helps compensate for road crown) I've swapped out the stock caster bushings on both my 2020 and now my 2022 with good results. The next step after caster bushings is to upgrade the steering stabilizer if you're still looking for additional improvement. I've run the through shaft Fox adjustable ATS steering stabilizer on both my 2020 and now my 2022 as well, and it also makes a noticeable improvement.
Old Dec 10, 2021 | 09:37 PM
JohnD333's Avatar
JohnD333
Do you have adaptive/active steering option?
Old Dec 10, 2021 | 10:24 PM
Adam R's Avatar
Adam R
I too complained about the steering in my 2019. Ford replaced a trackbar, steering stabilizer and a tie rod that were wearing prematurely around 20K miles. The biggest difference was when I swapped out the factory Goodyears for some better tires in a 285/75-18 size. The truck drives much better now, but one of these days I'll add some castor bushings as well. I have the snow plow package so I'm likely running even less castor than most trucks.
Adam
Old Dec 11, 2021 | 06:38 AM
Spokaloo Jim
JohnD333, I don't have adaptive steering but do have 20" wheels.
Old Oct 26, 2022 | 09:28 AM
Wmchris's Avatar
Wmchris
Seems around 4 degrees positive caster really makes a difference in stability. Took me 1 1/2 hour to replace the bushings on my ‘22 then had the alignment checked……it was right where it should be.
I got the bushings from SPC.
Did you use 4 degree on both sides?
Old Oct 26, 2022 | 09:44 AM
morehouse7's Avatar
morehouse7
You end up in that ~4 range of caster when done, but the bushings are SPC 2.3 and 2.6 degree.
https://www.spcalignment.com/index.p...tion&pid=23269
Old Oct 26, 2022 | 09:59 AM
Wmchris's Avatar
Wmchris
Thanks. Those are what I put in both of mine. Noticed more improvement on the truck with stock tires than I did on the one with 35/12.50s. May try an adjustable stabilizer on it.
Old Oct 26, 2022 | 12:38 PM
mcmurm's Avatar
mcmurm
I've done the same with the caster and my truck drove a lot better. +1 for SPC.
Old Oct 26, 2022 | 12:45 PM
  #28
Wmchris's Avatar
Wmchris
Did you find a sweet spot adjustment on the stabilizer? 1-24
prometheus1351
May 31, 2022 09:44 PM
SRock123
Apr 8, 2021 06:06 PM
drivn2drinkn
Mar 3, 2015 03:39 PM
metfancowboy
6.7L Power Stroke Diesel
15
Nov 21, 2014 11:59 AM
GuyPavelo
Aug 9, 2013 09:21 PM
