Aluminum bed damage
Old Jul 11, 2020 | 03:23 PM
s--k's Avatar
s--k
Aluminum bed damage
Anyone damage their bed hauling stuff?
Had axle housing in bed today. Road fine...except one left turn had a slight hump to it, axle rolled over 180 degrees and yoke punched a hole in my wheel well. Sucks.
Hindsight I should've strapped the axle housing. Never had moving objects in my other trucks cause damage like this though.
Old Jul 11, 2020 | 03:59 PM
Lamoon78's Avatar
Lamoon78
The wheel wells are really weak I tore a hole through one of mine. I beat it back closed and put some redhand on it sanded it smooth and put a bedliner and its gone.
Old Jul 11, 2020 | 04:27 PM
s--k's Avatar
s--k
I was pretty disappointed and embarrassed that I allowed this to happen and that Ford would have such a weakness.
Thanks Lamoon.
Old Jul 11, 2020 | 04:42 PM
Captain Call's Avatar
Captain Call
Mine was a week old when the first hole was punched in it from a piece of steel I set in there by hand and it rolled over. Pretty disappointing but oh well. I'll beat it for a few years and then line it.
Old Jul 11, 2020 | 04:53 PM
Ding126's Avatar
Ding126
Thank you for making me realize that i should tie it down...even if i think i won't need to. i would of done the exact same thing..honestly.
Old Jul 11, 2020 | 04:55 PM
Ding126's Avatar
Ding126
surprised some one doesn't make a hard shell cover that goes on with double sided tape.
Old Jul 11, 2020 | 05:11 PM
Absoluteblack2018's Avatar
Absoluteblack2018
If you have the spray in bed liner, you won't have such an issue. Line-x adds an incredible amount of strength to any material its sprayed on.
​​​​​​https://www.youtube.com/watch?v=K5VTAW7LZEM
Old Jul 11, 2020 | 05:31 PM
AK2NC's Avatar
AK2NC
Well, I've seen the commercials
Old Jul 11, 2020 | 06:04 PM
Lamoon78's Avatar
Lamoon78
Thanks Lamoon.
Mine was a empty hard plastic 200 gallon water tank I use at the deer lease to haul water in. It slid across the bed and the corner punched right through it.
Old Jul 11, 2020 | 07:30 PM
fordman19762003's Avatar
fordman19762003
Every time I walk on the tailgate I can hear it creak and feel it flex, it doesn't inspire confidence. I've also noticed that you can push under the Ford emblem and the outer skin will push in.
Old Jul 11, 2020 | 11:21 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Beer can trucks. Be careful with them.
Its a good argument for a plastic drop-in liner
Old Jul 11, 2020 | 11:25 PM
Louisville Joe's Avatar
Louisville Joe
Spray-in liner like Line-X really does add strength.
Old Jul 12, 2020 | 12:20 AM
Lamoon78's Avatar
Lamoon78
No issues after a bedliner was sprayed in.
Old Jul 12, 2020 | 08:58 AM
ejb69's Avatar
ejb69
A good plastic drop in liner offers the best protection for trucks that see hard use. I have seen the sprayed on liners get scraped off many times when using a fork lift to push pallets to the front of the box. My employer has stopped getting any type of liner for their trucks and instead just puts a sheet of plywood or steel in the box.
My personal truck has a sprayed on liner because the dealership had it put on. It works fine for me as l am some what careful with it.
Old Jul 12, 2020 | 09:11 AM
DaveZX's Avatar
DaveZX
Aluminum bed damage
I prefer drop in liner for durability. It is more slippery, which often is an advantage loading and unloading. Easier to clean too.
On this truck with 5th wheel hitch, I felt like I had to go spray in.
Not tying stuff down bites us in the butt. I've done my share of second guessing mess ups.
